Scratch Build – In Progress Project Intel "Ice" Video added 07/24/10 liquid resin case
Discussion in 'Project Logs' started by jj_sky5000, 11 Jun 2010.
  1. jj_sky5000
    jj_sky5000 Minimodder
    25 Dec 2009
    Well after a long break I am back at doing some modding projects, I have 4 total that I wanted to have completed by the end of the year.
    The first Mod is called Intel Ice, Featuring a Intel® Desktop Board D945GSEJT Atom CPU mini itx Board Sponsored by Intel, Looking to make it my Home Media Server. I t will set in a a Custom fake arclyic ice case. Let Begin
    Parts List
    Plexi Glass
    Plastic Resin
    Vandal Switch
    DC power adapter ( on order)
    Intel® Desktop Board D945GSEJT Mother Board Sponsored by Intel!!!!
    PCi min express wireless Card ( on order)
    Wireless Logitech Keyboard and mouse
    Western Digital hard drive
    Win 7
    2 80 mm Blue led fans
    mixing bowl /wood spoon
    aluminium foil
    2 boxs one slightly bigger than the other!!!
    The mold Not much Card Board and aluminum foil
    Lets Begin
    64 fl oz of Plastic resin 1/2 oz of catalyst hardner
    Mixed it it for 60 sec
    Poured the top of the case in the moldto about 1/2 inch deep. Then waited 30 min till it start to gel then I put a second box on top to make inside walls. pour the remaining resin in to make the walls.
    I had to apply a little weight on top of the inside box to keep from floating up.
    This will set overnite to cure and make sure you are in a well ventilated area.
    knuck likes this.
  2. StEm
    StEm What's a Dremel?
    30 Nov 2009
    That is such a clever idea to get the ice effect with the foil giving it the creases and shapes, I have a good feeling about this one!!!
    Why cant I think of clever stuff like this?? lol
  3. bulldogjeff
    2 Mar 2010
    I've seen this affect before but never actually seen any 1 do it, looks like it's off to a good start
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    That's a great idea and it makes the process of resin-cating so much more easier.
    I'm trying to cast a case for an mITX-system aswell, but I was more thinking of something with an even and polished finish and I've troubles to make the moulds... resin-casting with 0.5mm clearance isn't particularily easy, if you don't have a CNC to mill the moulds :D
  5. Nicksen
    Nicksen Danish Kid :D
    16 May 2010
    Looks interesting. Keep working! Wanna see where this is going :)
  6. Cheapskate
    13 May 2007
    What are you using to keep the mold from leaking? I've always wanted to try doing this stuff.
  7. jj_sky5000
    25 Dec 2009
    @cheapskate, that was one of my biggest worries. But by far this is the cheapest mold you can make (lol). I though of using clay or latax molds, but that gets costly. It did leak a little out of the almumin and box, The resin gets thick and gels in about 30 minutes. its just very minor. i watch it stop before my very eyes
  8. jj_sky5000
    25 Dec 2009
    Time to un wrap
    I did spray a resin release agent before i poured the mold so it would stick too bad.
    To square it up I did a little cutting with a dremal & hack saw!!!
    Ok took a few shots to see how it looks on different surfaces
    a little more work on the cover and then i will start on the base
    matt... likes this.
  9. Monsta
    Monsta Dremel Blades in ma head!
    7 Jun 2010
    :jawdrop:
    wow, that really looks like a block of ice :idea:
  10. Anubus
    Anubus Minimodder
    7 Jul 2008
    This is going to be interesting.
    I can't wait to see the end. :thumb:
  11. knuck
    knuck Hate your face
    25 Jan 2002
    that's an awesome effect right there. Very impressive ! :thumb:
  12. Jipa
    5 Feb 2004
    Great idea with the resin/aluminum foil. Now I really want to try casting something :)
  13. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    ^Careful, you might get chemical burns... :worried: :naughty:
    Does look just like a giant chunk of ice, so, perfect so far. :)
  14. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    Having spent a lot of time working with polyester casting resin in the past six months, I'd like to tell you to watch out as a safety point. The catalyst itself is not nice, and whilst the clear resin is slightly more benign, it can still cause problems, even when hardened if you're touching it a lot. I'm not trying to make you think it's deadly or whatever, but if you're touching it a lot and have sensitive skin, it can be an irritant.
  15. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    Oooo that looks awesome! Nice job!
  16. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    Sweet! very creative casting technique and the result is perfect. I'm watching :D
  17. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Looks pretty sweet, I can't wait to see who this turns out
  18. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    As everyone I'm impressed. It's look's like a giant ice cube.
  19. speeDs_
    speeDs_ What's a Dremel?
    1 Apr 2010
    Wow nice idea, and very creative ! I will follow this for sure. :)
  20. Monkey Puzzle
    Monkey Puzzle Minimodder
    18 Feb 2009
    ah very interesting - good effect with the resin. :) What's the name of the release agent spray?
