Planning Where can I get an ATX Backplate Diagram?
Discussion in 'Modding' started by Langer, 7 Sep 2010.
  1. Langer
    Langer Jesse Lang
    24 Jan 2004
    Does anyone know where I can get a vector drawing of an entire ATX backplate?
    Something like this - but just a simple line drawing with measurements?
    I'd prefer not to have to dig one of my rigs out of storage just to measure the backplate - I haven't yet moved my stuff into my new apartment and don't have a PC case at hand.
    Thanks in advance.
    *j
  2. talladega
    talladega I'm Squidward
    18 Aug 2007
    I THINK that cheaps cut one with his CNC.
  3. Langer
    Langer Jesse Lang
    24 Jan 2004
    An amazingly awesome cat named Josh sent me an email with no text, just an attachment in the form of an EPS file.
    Whoever you are - THANK YOU SO MUCH.
    In the interest of saving anyone else from this headache I've uploaded the *.eps file to my server and now offer it up to the community as a small sign of my appreciation!
    *click for download*
    *j
  4. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    that's awesome, its the bit that always stubs me as the ATX 2.2 standard doesn't really cover such a thing with regards to dimensions of the PCI expansion ports.
  5. Cheapskate
    13 May 2007
    snagged
    -and I think it was Rambo that recently milled out a backplate from billet.
  6. Burnout21
    9 Sep 2005
    he did, im sure of it. Solid billet
  7. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    So Rambo's the one to hound for measurements? Darned PCI people won't send you the measurements unless you're a member of the club - so much for open standards!
  8. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    I cannot remember where I got it from, but I have the PCI version 10a specification.
    It is just over 1MB.
    PM me if interested.
  9. Langer
    Langer Jesse Lang
    24 Jan 2004
  10. Burnout21
    9 Sep 2005
    DXF if possible chap...
  11. Langer
    Langer Jesse Lang
    24 Jan 2004
    HERE'S A DWG (illustrator doesn't like DXF exporting, it fubars everything)
    Cheapskate likes this.
  12. Burnout21
    9 Sep 2005
    thank you!
  13. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    Wow solid billet one, now theres an idea....
    Well i punched and folded mine from 1mm ally and added m3 steel inserts.
    I used an old one from a coolermaster atc210 case (now that brings back memories).
    and just followed the dimensions to continue it into a 10 pci version.
    So i didnt do a drawing myself.. ooops bad practice, but there you go.
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    It was the solid billet one that instantly inspired me to make my own :rock:.
    Finally come up with a great & simple method by using layers I think it's one of those too simple things that no one thinks of it lol :D.
    I have it fully designed in sketchup, took precise measurements of a good Lian-Li one & made it in sketchup, I also made an XL-ATX back panel too & could just as easily make a micro or mini back panel.
    I know I could very easily make them & at a low cost, my original design was a bunch of aluminium layers but I finalised my design to have plexi glass sandwiched between sheet aluminium which would be great for tapping & look cool too :thumb:.
    Really looking forward to making my next case not relying on a salvaged pci piece :D.
    So, how do I share the sketchup file, let me know & I'll get it up, about time I contributed to the modding community :).
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Just took a couple of snips of what I mean :rock:.
    Standard ATX
    XL-ATX
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Here I used winrar to pack it & includes both ATX & XL-ATX pci back pieces made from google sketchup 7. Also added this to the sketchup collection :).
    This is imo the easiest way to make them :thumb:.
    http://www.mediafire.com/?zilaf6qd6cjzicy
  17. MrBean
    MrBean Minimodder
    21 Apr 2004
    Hello Guys,
    sorry to be dragging up an old post - anyone here still have the ATX CAD drawing available for ATX or micro-ATX?
    Need it for a new project, and will save me heaps of time :)
    Much obliged, Phillip aka mrbean
