Scratch Build – In Progress XFX Fire & Ice
Discussion in 'Project Logs' started by jj_sky5000, 20 Feb 2013.
  1. jj_sky5000
    jj_sky5000 Minimodder
    25 Dec 2009
    Well I had a little time between Lan parties and Builds ( still waiting for one to come back) I had this concept before in 2009 and after a few complete ice mods I was ready to attempt to build it. The build will be called Fire & Ice, making the case from liquid resin and trying to use a least amount of metal possible with a waterfall reservoir.
    I purchased the ECS model P67H2-A2 Deluxe
    I like to thank my sponsors for supporting my projects over the years.
    A have a long way to go and a short time frame, Do you think i can make it?
  2. jj_sky5000
    25 Dec 2009
    First thing is getting my layout on The board that i will be using for my mold and double checking measurements.
    adding 2 by 4 and attaching them with screws from the back
    getting a 3d visual in my mind ,
    Side view of the side panel
    Molds are ready
    Am I making cookies or a case mod you decide
    Ready to Pour
    make sure you add you Mold release
    Sorry for the blur i was probley dizzy from the fumes
    Mixing the resin with the catalyst
    I let it set over the next 24 hours
    Ok need to keep pushing on this if i am going to get done
    Vote every day till the end for your favorite
    http://www.ecsmodmen.com/
  3. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    hmm.. resin.. thats how you made that icy look.. interesting..
  4. jj_sky5000
    25 Dec 2009
    After letting the resin harded for about 2days here is the end result
    One cool side panel
    all cleaned up
    getting a good idea on attaching the fans
    front panel fan placement
    rounting the front & side panels for Plex glass Insert
    Side panel sanding from 50 , 150, 400 , 1000 grit.
    More plexi has arrived to finish my newest feature to the case.
  5. Cheapskate
    13 May 2007
    Wait. This is a new one?:duh: I saw it over on ModZoo and thought you were adding an older log.:lol: -Senility sucks.
    I like the idea of adding plexi to cast. will you be gluing/fusing it?
  6. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    I thought the same :lol:
    Looks good so far.
  7. jj_sky5000
    25 Dec 2009
    I have a few older ones out there.
    But this one is live and new as its gets! my wife says i smell like resin.
    I will be glueing some in and fusing the top panel.
  8. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    hi jj_sky5000, first of all well done for a very interestin g worklog, is really something new i like it.
    i also have a question, maybe you could help me with.
    did you have any difficulty getting your data up to the ecsmodmen site.
    i opened an account and set it up them after i had confirmed it via email, i could also log in.
    the first time i was in it said click on the account button to change my data etc.. after i did that all i got was a (my account is being axamined and i should wait for the email saying i am fully loginable.
    i thought ok, but then wehn i now login, all i get is click on the account button below, which is not there. it just doesnt appear. have cleared all temps and cookies etc.. have used other computers too and also my smart phone, always the same phenomena. do you have this problem too.
    i even sent a email like advised to info@ecsmodmen.com and get a nt deliverable message, non existing. something is very wrong, even the emil add. wont work.
    appreciate any help you can give, are you also haveing problems.
    thanks a lot mate, and keep up the good work.
    ali abbas
    here is a pic of the message i get. i entered over a week ago.
    [​IMG][/IMG]
  9. jj_sky5000
    25 Dec 2009
    I have No trouble logging into account. Did you register under a different email for the mod ?
  10. jj_sky5000
    25 Dec 2009
    Dont forget to go and vote!!!! 2 1/2 days left. http://www.ecsmodmen.com/ I am pushing hard to finish it.
    Adding the case fans!!!
    I wanted to do something different and cut them out myself instead of using the large hole cutter.
    trusting old craftmans scroll saw
    Setting the blade through the pre drill holes
    A little etching action
    testing the LEPA fans
    and the other side again cutting out the fan holes
    Thanks again for taking a look.
  11. Johnny71
    Johnny71 What's a Dremel?
    6 Jun 2012
    Awesome work man! Will be following the rest!:)
  12. jj_sky5000
    25 Dec 2009
    More ecthing work. If you like the build , Dont forget to vote , Voting ends 3/5
    (Spolier alert) http://www.ecsmodmen.com/entries/5123j26QWE95
    Can any body quess why i did the wording on 2 different sheets?
    every body need a little fire dragon
    Start my second very time consuming project with the plexi & weld on #4
    Probley a day between each pic
    this is all cut by a table saw and sandpaper , no lazer here
    a little water test for my first ever Custom reservoir
    thank you for subbing and following along 5
    voting page (Spolier alert) http://www.ecsmodmen.com/entries/5123j26QWE95
  13. jj_sky5000
    25 Dec 2009
    Started working on the Floating tier for the MB. Thank you old trusting Intel for making a perfect template for Drilling holes for Standoffs
    TAP, TAp, TAp
    Found some arcylic Rods and wanted to incoportae them into the Build
    Getting a idea on how its going to look
    A last minute decision to make my own case feet
    Mounted to the base
    I am going to leave you with a teaser Pic
  14. jj_sky5000
    25 Dec 2009
    Small update,
    using a small bit of clear epoxy to secure the sides to each other and base.
    adding a hinge back panel
    Installing hardware
    water testing
    Preview update coming later tonight.
  15. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Wow this is really beginning to look incredible! I love the idea of wrapping the reservoir around the components themselves, very novel, it's also a pretty ballsy move so good luck. The ice effect from the resin is really striking.
  16. jj_sky5000
    25 Dec 2009
    Preview update
    16 hours left in the voting for the ecs Modmen comptetion , Please go vote!!!!
    Here is a little preview of Fire and Ice
    A big thank you to all the sponsors involved in the project, Intel, LEPA, ADATA & Seasonic, & ecs for hosting a amaizing contest.
    More to come, !!! sleeving and better lighting !!!
  17. Cheapskate
    13 May 2007
    Crazy, Man! :thumb: Nice idea too. The dripping on the res makes it look like it's trying to melt.
  18. jj_sky5000
    25 Dec 2009
    Thank you Cheapskate, tried to make this ice case a little different than the other 4 lol, that was my first rez, now i have tons more ideas now that i made one. i dont recommend a table saw and a palm sander when making one through lol
  19. bulldogjeff
    2 Mar 2010
    Oh wow.. I really do like that. The effect is brilliant.
  20. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    oh wow I love that res effect! incredible job!
