Hey Well as the title says in the AMD VISION engine control center it can only recognise 2 of my displays, it only see's the 2 monitors running on the dvi ports on my 6950, my third monitor is on and active display port to dvi. Here's what CCC is showing. http://imgur.com/xJ5zD Thanks! Duncan
is the third display set to display on displayport and not dvi or hdmi (or *gasp* vga!)? That might be it.
i have a g2420hd screen, to change between d-sub (vga), hdmi and vga i have to press the enter button 'till the proper input is shown, maybe yours works the same way
