Motherboards Installing an older bios
Discussion in 'Tech Support' started by CrapBag, 18 Jan 2016.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I have been having trouble with a 2400s not functioning fully in my Asus P8H61-I in that the pcie gpu won't be detected.
    Chip is fine as tested it in another board.
    I wanted to back track to an older BIOS but it won't let me saying its out dated.
    Should I be able to install an older BIOS?
  2. Guest-56605
    Guest-56605 Guest
    It depends on the board and BIOS in question, after a given revision you can only roll back so far with some (normally there is a warning/BIOS note to indicate this).
  3. Big Elf
    23 Apr 2009
    How are you trying to install the BIOS? I've usually had good results using Asus EZ Flash from within the BIOS itself using a USB stick. After saying that I haven't done it on a recent motherboard only socket 775 and 1366.
  4. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Yup using EZ flash from the bios.
    I think it's a lost cause and I'm going to have to sell the 2400S and buy something else, undoubtedly dearer.
