Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 29th Sep 2007, 13:50   #61
Colossous
Hypermodder
Colossous's Avatar
Colossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run CrysisColossous can run Crysis
1st proper mod, new one soon !!
http://forums.bit-tech.net/showthread.php?t=135169
Colossous is offline   Reply With Quote
Old 22nd Oct 2007, 05:25   #62
ranlai
Multimodder
ranlai has yet to learn the way of the Dremel
Tortoise Beetles
ranlai is offline   Reply With Quote
Old 22nd Oct 2007, 18:06   #63
ranlai
Multimodder
MY R2
http://armygroup.com.tw/images/mod/r/185.jpg
http://armygroup.com.tw/images/mod/r/189.jpg
http://armygroup.com.tw/images/mod/r/191.jpg
http://armygroup.com.tw/images/mod/r/188.jpg
Old 22nd Nov 2007, 21:33   #64
Mysterae
Minimodder
Mysterae has yet to learn the way of the Dremel
Parallel Hex
I should have started this here, perhaps I will when I upgrade it .
This is a 6 loop parallel water cooled PC. AMD 4400+, X1900XTX Crossfire, plus high current laser .
Can I please have one more pic, please?! It explains the elaborate plumbing...
The full worklog with lots of pics can be found here.
Some random videos of strange goings on with the water cooling in the reservior:
Video 1 of 6 - Night time illumination, shows the bubbling effect in the Collector.
Video 2 of 6 - Day time lighting, starts with the Collector effect, then reducing it.
Video 3 of 6 - Day time lighting, close up of the Collector effect and a general pan.
Video 4 of 6 - Night time illumination, with the laser being activated.
Video 5 of 6 - Night time illumination, with the laser being activated (again but longer).
Video 6 of 6 - Day time lighting, with the collector effect very visible.
__________________
_________________
parallel_HEX
Mysterae is offline   Reply With Quote
Old 2nd Dec 2007, 05:59   #65
MegadetHCl
Modder
MegadetHCl has yet to learn the way of the Dremel
Full thread here.
MegadetHCl is offline   Reply With Quote
Old 9th Dec 2007, 06:23   #66
Luxorz
What's a Dremel?
Luxorz has yet to learn the way of the Dremel
Such incredible work displayed on Bit-tech... I'm almost ashamed of my v1000b. I tried to keep it all inside the case. No windows or fancy lighting but it performs
http://picasaweb.google.com/bbopptec...56807992022882
Luxorz is offline   Reply With Quote
Old 12th Dec 2007, 12:45   #67
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
This is the Qmicra v2 SFF mod I performed for PCDesignLab.
I posted video on how to paint black gloss enamel finish with spray paint in bit-tech Guides
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 1st Jan 2008, 22:32   #68
bobdahaxor
What's a Dremel?
bobdahaxor has yet to learn the way of the Dremel
My first mod
I took my cooler master stacker, added a window, put a green cathode, got a giant thermaltake copper tower, got some cool fans, tucked away all the cables and this is what it is at now. I know it is not much and ya'll probably laugh at it, but here it is and please critique and gimme some good ideas to mod it further and make it look better (please no water cooling or something that is outrageously expensive) Specs: AMD Athlon 64 3500+ @ 2.42Ghz, Asus A8N5x mobo, 2Gb DDR400, eVGA 7800GT @ 495core and 1222mem, DVD drive, DVD-RW drive, 500watt Thermaltake PSU
bobdahaxor is offline   Reply With Quote
Old 14th Jan 2008, 23:42   #69
Hasle
nohasslemods›
Hasle's Avatar
Hasle has yet to learn the way of the Dremel
The Purple Dragon Project
My first and only mod (so far).
Case: Chieftec Dragon DX-01PL-D-U
Select key features:
- Inside painted flat black and all unnecessary interior items have been removed.
- Four 80mm fans mounted in the front in a custom mounting plate.
- Top and side window created using dark tinted acrylic.
- Top window has a recessed fan controller w. LCD display.
- Also in the top window is a key that needs to be turned for the PC to be switched on, and a Bulgin button.
- And lots, lots more - check the log.
Link to log (2nd page with pictures of the completed mod): The Purple Dragon Project
__________________
 Z170 Stinger  │  6700K  │  TITAN X  │  32GB DDR4  │  MANTA  │   j u i c e b o x
 X99-S  │  5820K  │  GTX 980  │  16GB DDR4  │  Corsair 760T  │   t r o o p e r
nohasslemods
Hasle is offline   Reply With Quote
Old 15th Jan 2008, 09:11   #70
HaoKi
Lleno de anguilas!
HaoKi has yet to learn the way of the Dremel
The Eutanasia-Project
Here's my completely custom built gaming rig.
The case was designed and built to be small and durable. It has the dimensions of an matx-case but it still houses a full-atx system.
It has watercooling for the CPU and enough space to fit SLI into it. In addition the case itself hardly restricts the used components.
Project: Eutanasia on Metku.net
__________________
MetkuMods Because you love your hardware.
AllTheMods Modded your house, bike, computer?! Show-off it here.
Eutanasia: Q6600 g0 @ 3,6Ghz, DFI Lanparty DK X48-T2RS, 4Gb G.Skill @ 912mhz 5-4-4-4, HD4870 CrossfireX, 200gb WD... Article: Metku.net
HaoKi is offline   Reply With Quote
Old 17th Jan 2008, 16:36   #71
robyholmes
I'm under your desk...
robyholmes's Avatar
robyholmes has yet to learn the way of the Dremel
Lian Li
By Rob Holmes (robyholmes)
Slideshow
Spec:
Core 2 Duo E6400 2.13Ghz @ 3.1Ghz
Cosair Dominmator 2Gb 1066Mhz
Asus P5E x38
EVGA Geforce 8800 GTS (Super Overclocked)
320Gb SATAII
DVD-RW SATA
Coolmaster 600W blue sries
Lian Li V1100B Plus II
OS:
Vista 32Bit
Ubuntu 7.10
robyholmes is offline   Reply With Quote
Old 18th Jan 2008, 07:52   #72
rchiileea
Supermodder
rchiileea has yet to learn the way of the Dremelrchiileea has yet to learn the way of the Dremelrchiileea has yet to learn the way of the Dremel
Mod was called fusion AA (to represent the fusion of amd and ati) all the panels apart from io were custom made by us. all the etching on this case was also done by hand and using the dotinism technique.
http://www.xtremecomputing.co.uk/ima...usionAA_41.jpg
Link to large pic of the spider etch on the mobo back panel
Roof etchings
http://www.xtremecomputing.co.uk/ima...usionAA_31.jpg
http://www.xtremecomputing.co.uk/ima...usionAA_30.jpg
Main panel etch (the best imho)
http://www.xtremecomputing.co.uk/ima...usionAA_24.jpg
[IMG]http://www.xtremecomputing.co.uk/images/mods/FusionAA/FusionAA/FusionAA_13.jpg
http://www.xtremecomputing.co.uk/ima...usionAA_15.jpg
The log is here
Last edited by Bindibadgi; 15th Sep 2008 at 15:10. Reason: ONE picture - read thread rules
rchiileea is offline   Reply With Quote
Old 14th Feb 2008, 03:46   #73
Syrillian
What's a Dremel?
Syrillian has yet to learn the way of the Dremel
Custom acrylic case
Dual liquid loops, horizontal motherboard, separate thermal zones.
Halcyon:
Syrillian is offline   Reply With Quote
Old 15th Feb 2008, 12:07   #74
mnpctech
bit-tech sponsor
mnpctech's Avatar
PR Tribute PC Worklog Link
Watercooled Intel / Tyan Server one side, Watercooled AMD / DFI SLI Gaming system on the other.
The cards, memory and HDs are being installed by somebody else.
__________________
Old 27th Feb 2008, 22:26   #75
GuardianStorm
Ultramodder
GuardianStorm's Avatar
GuardianStorm has yet to learn the way of the Dremel
Fully log here
__________________
Sites: My Site :: My blog
Tools: Project Log Previewer
Curent Projects: Dark Vortex
Finished Projects: Yarrrbox :: Laptop Stand :: Bench PSU MK2 :: FS2
Guides: How To Bend Metal
GuardianStorm is offline   Reply With Quote
Old 16th Mar 2008, 11:58   #76
megadega
Minimodder
megadega's Avatar
megadega has yet to learn the way of the Dremel
My Computer in Keg
My Computer in Keg
http://youtube.com/watch?v=-UK76anc_sM
http://mod-planet.com/index.php?modu...age&pageid=822
megadega is offline   Reply With Quote
Old 20th Mar 2008, 03:58   #77
Americanfreak
What's a Dremel?
Americanfreak has yet to learn the way of the Dremel
Check out more here at Modders-Inc
(To the post below...Sorry, dang hotlink blocking. You should see the images now and those links are dead. -AF)
Americanfreak is offline   Reply With Quote
Old 20th Mar 2008, 10:18   #78
mnpctech
bit-tech sponsor
mnpctech's Avatar
Modified case for AMD. More info and photos in bit-tech thread
__________________
Old 25th Apr 2008, 18:54   #79
willowthewhite
Multimodder
willowthewhite is a hoopy frood who really knows where their towel is.willowthewhite is a hoopy frood who really knows where their towel is.willowthewhite is a hoopy frood who really knows where their towel is.willowthewhite is a hoopy frood who really knows where their towel is.willowthewhite is a hoopy frood who really knows where their towel is.willowthewhite is a hoopy frood who really knows where their towel is.willowthewhite is a hoopy frood who really knows where their towel is.willowthewhite is a hoopy frood who really knows where their towel is.willowthewhite is a hoopy frood who really knows where their towel is.willowthewhite is a hoopy frood who really knows where their towel is.willowthewhite is a hoopy frood who really knows where their towel is.
Antec P182
Full work log Here.
willowthewhite is offline   Reply With Quote
Old 25th Apr 2008, 19:16   #80
Koradhil
Supermodder
Koradhil's Avatar
Koradhil has yet to learn the way of the Dremel
I made a Cosmos 1000 casemod for Cooler Master. It was on display at CeBIT 2008 and will be featured in the next edition of CustomPC Magazine.
http://www.core-modding.nl/datas/users/protoss2s.jpg
http://www.core-modding.nl/datas/users/protoss3s.jpg
http://www.core-modding.nl/datas/users/protoss4s.jpg
The worklog is here.
__________________
» BRAND NEW SITE
Projects: Nimex | Gemini | Aquamedia | Mystique | Orion | Protoss
Powered by A.C.Ryan, Cooler Master, Corsair, EPoX, PQI, Recom, Revoltec, Sapphire.
Koradhil is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
