Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 17th May 2008, 04:13   #81
KingKinase
7 1/2 " 4 T W
KingKinase has yet to learn the way of the Dremel
Glasson Lumber:
Log Right Here
Thanks again Tom :>
KingKinase is offline   Reply With Quote
Old 18th May 2008, 23:16   #82
vashant
What's a Dremel?
vashant has yet to learn the way of the Dremel
The Hardwood Dominator.
Hi, this is my first mod and I think it came out good.
I built it for ease of use and cooling performance. Hope you like it.
http://tifftsgifts.com/11111/aP5100340.jpg
http://tifftsgifts.com/11111/aP5100339.jpg
Much more info such as additional pictures, specs and the making of it can be found at this link:
http://www.modshop.net/users/vashant...wood-dominator
vashant is offline   Reply With Quote
Old 20th May 2008, 14:08   #83
steelkane
It's Not Just A Box
steelkane has yet to learn the way of the Dremel
WOW, Looking at all the pimp rigs, there really nice & theres allot of them that I like better then mine,, But I'm proud of my build, don't know if it can compare to some that I've seen here, but here it is.
http://www.hackmyitouch.com/steelkan...0/SS855407.jpg
http://www.hackmyitouch.com/steelkan...0/SS855406.jpg
http://www.hackmyitouch.com/steelkan...st/S2DTF15.jpg
http://www.hackmyitouch.com/steelkan...ost/S2DTF2.jpg
http://www.hackmyitouch.com/steelkan...ost/S2DTF3.jpg
http://www.hackmyitouch.com/steelkan...ost/S2DTF4.jpg
http://www.hackmyitouch.com/steelkan...0x%201200).jpg
http://www.hackmyitouch.com/steelkane/SS851803.jpg
http://www.hackmyitouch.com/steelkane/SS851813.jpg
http://www.hackmyitouch.com/steelkane/SS851816.jpg
http://www.hackmyitouch.com/steelkane/SS851817.jpg
http://www.hackmyitouch.com/steelkane/SS851823.jpg
http://www.hackmyitouch.com/steelkane/SS851825.jpg
http://www.hackmyitouch.com/steelkane/SS851826.jpg
http://www.hackmyitouch.com/steelkane/SS851829.jpg
http://www.hackmyitouch.com/steelkane/SS851836.jpg
http://www.hackmyitouch.com/steelkane/SS851866.jpg
http://www.hackmyitouch.com/steelkane/SS851889.jpg
http://www.hackmyitouch.com/steelkane/SS851890.jpg
http://www.hackmyitouch.com/steelkane/SS851894.jpg
http://www.hackmyitouch.com/steelkane/3.jpg
http://www.hackmyitouch.com/steelkane/13.jpg
http://www.hackmyitouch.com/steelkane/14.jpg
http://www.hackmyitouch.com/steelkane/SS851934.jpg
http://www.hackmyitouch.com/steelkane/SS851973.jpg
http://www.hackmyitouch.com/steelkane/SS851985.jpg
http://www.hackmyitouch.com/steelkane/SS852719.jpg
http://www.hackmyitouch.com/steelkane/SS852435.jpg
http://www.hackmyitouch.com/steelkane/SS852464.jpg
http://www.hackmyitouch.com/steelkane/SS852482.jpg
http://www.hackmyitouch.com/steelkane/SS852473.jpg
http://www.hackmyitouch.com/steelkane/7sp.jpg
http://www.hackmyitouch.com/steelkan...00x600/1sp.jpg
http://www.hackmyitouch.com/steelkan...00x600/sp3.jpg
http://www.hackmyitouch.com/steelkan...Resize/4tb.jpg
http://www.hackmyitouch.com/steelkan...Resize/1tb.jpg
http://www.hackmyitouch.com/steelkan...Resize/2tb.jpg
http://www.hackmyitouch.com/steelkan...Resize/5tb.jpg
http://www.hackmyitouch.com/steelkan...Resize/6tb.jpg
http://www.hackmyitouch.com/steelkan...Resize/8tb.jpg
http://www.hackmyitouch.com/steelkan...e/SS852865.jpg
http://www.hackmyitouch.com/steelkan...e/SS852871.jpg
http://www.hackmyitouch.com/steelkan...e/SS852875.jpg
http://www.hackmyitouch.com/steelkan...e/SS852889.jpg
http://www.hackmyitouch.com/steelkan...e/SS852896.jpg
http://www.hackmyitouch.com/steelkan...e/SS852901.jpg
http://www.hackmyitouch.com/steelkan...e/SS852915.jpg
http://www.hackmyitouch.com/steelkan...e/SS852933.jpg
http://www.hackmyitouch.com/steelkane/SS852928.jpg
http://www.hackmyitouch.com/steelkane/SS852927.jpg
http://www.hackmyitouch.com/steelkane/FlameD1.jpg
http://www.hackmyitouch.com/steelkan.../FlameCout.jpg
http://www.hackmyitouch.com/steelkan...size/HDDF1.jpg
http://www.hackmyitouch.com/steelkan...0/SS854053.jpg
http://www.hackmyitouch.com/steelkan...0/SS854058.jpg
http://www.hackmyitouch.com/steelkan...r/P1030677.JPG
http://www.hackmyitouch.com/steelkan...e/SS852176.jpg
steelkane is offline   Reply With Quote
Old 25th May 2008, 03:23   #84
W-fault
Otherwise known as widefault
W-fault has yet to learn the way of the Dremel
First time I've posted these here, some might have seen these at other websites.
All three of these are built around old aluminum breadboxes, specifically this model.
They're not much to look at, but they have an interesting curve to the rear that I really liked. I bought my first one for 50 cents at a thrift shop quite a few years back, I was going to use it as is and fit in a full ATX system. It never developed, and ended up sitting on the floor for quite a few years until I got a better idea. The second breadbox I bought last year, and ended up paying $20. I thought that was too much, but recently I've seen these selling for around $60 on ebay. Insane.
Anyway, the first breadbox was cut up to build a custom case for an embedded Core 2 Duo setup which is now my work PC. The main body is obviously from the breadbox, but the backplate is made from the internal shelf, and left over aluminum made up an internal fan bracket.
More pics and specs here. Specs are out of date, currently only has an 80GB drive. Oh, the slot for the DVD was done by hand. Drew a line on with a pencil, drilled a hole on each end, then used a file to go from hole to hole. Surprisingly it only took about a half hour.
The inner shelf from the second breadbox became the main part of this system's case.
Based on another embedded board, I built it just to see how small a PC I could build. I did end up adding HD and power LEDs, power and reset switches, and a couple fans.
The bulk of the last breadbox became the body for this.
That's my current Windows Home Server, based on a mini-ITX board with a Yonah-core Celeron.
I had to buy actual aluminum to make the base and back, but I was able to buy some cheap scrap which worked nicely. More pics and out-of-date specs here.
Oh, and all three systems also use black AC Ryan mesh. I bought one sheet and it's lasted me much longer than I thought it would. I even had enough left to build this.
That's a remote power and reset switch with power LED. The gauge acts as a HD indicator. More on that here.
W-fault is offline   Reply With Quote
Old 1st Jun 2008, 08:07   #85
MarkHorridge
Mark Horridge
MarkHorridge has yet to learn the way of the Dremel
Wooden PC
PC case constructed from Australian timber in May 2008 by Mark Horridge.
Motherboard is placed horizontally, above the PSU. Two large fans (one in, one out) move
air over the heatsink and through the case. The fan grilles were once headlight
protectors for an MG sportscar. On the top is a circular window, with glass from an old
wall-clock.
Some more pictures at:
http://www.monash.edu.au/policy/woodpc.htm
MarkHorridge is offline   Reply With Quote
Old 2nd Jun 2008, 16:40   #86
Anttifast
What's a Dremel?
Anttifast has yet to learn the way of the Dremel
Amplifier-Htpc
Worklog and more pics in AllTheMods
Anttifast is offline   Reply With Quote
Old 14th Jun 2008, 08:32   #87
rchiileea
Supermodder
rchiileea has yet to learn the way of the Dremelrchiileea has yet to learn the way of the Dremelrchiileea has yet to learn the way of the Dremel
Project plus - work in progress
Inspired by insanity (must of been as it was really hard work) This project sparked off in 2007 and has took a long while to get started, and a long while to get right. but here is what i have done so far
Yes I really did take apart a tj07 and cover it in cream leather :P Ill add log once its all complete if mods dont mind
rchiileea is offline   Reply With Quote
Old 16th Jun 2008, 05:51   #88
JPHarvey
What's a Dremel?
JPHarvey has yet to learn the way of the Dremel
My ANTEC Nine Hundred Watercoooled...
Here is my compact addition to the mix....
Computer Bits:
Case - Antec Nine Hundred
CPU - E6600
MoBo - P5N32-SLI Premium
RAM - XMS2 DDR-800 4-4-4-12
GPU - XFX 8800GTX SLI
Cooling Bits:
CPU - D-Tek Fuzion
GPU - 2 x EK8800 Full Block
Rads - 1 x Swiftech 120, 1 x Swiftech 220
Pump - Swiftech Laing D5
Res - Swiftech Micro
Piccies
http://i252.photobucket.com/albums/h...PCSideOpen.jpg
http://i252.photobucket.com/albums/h.../PCInnards.jpg
http://i252.photobucket.com/albums/h...vey/PCRear.jpg
JPHarvey is offline   Reply With Quote
Old 27th Jun 2008, 00:13   #89
tJev
Bye bye modding-virginity
tJev has yet to learn the way of the Dremel
My first case mod/build
More pics can be found in my short work log: http://forums.bit-tech.net/showthread.php?t=153546
tJev is offline   Reply With Quote
Old 27th Jun 2008, 14:52   #90
Hazardous
Mod Master
Hazardous's Avatar
Hazardous has yet to learn the way of the Dremel
What's with the multiple pics and multiple links... posts 85, 87, 88, 89, 94 in particular
I don't mind of this post gets deleted, but some folks obviously need reminding by someone, of the rules for this forum section:
One 'taster' picture only per case.... Add a few brief details.
__________________
Beauty is in the eye of the beer-holder
Hazardous is offline   Reply With Quote
Old 28th Jun 2008, 16:52   #91
razer121
What's a Dremel?
razer121's Avatar
razer121 has yet to learn the way of the Dremel
pipeline, first proper decent mod,
Read the post above yours
razer121 is offline   Reply With Quote
Old 10th Jul 2008, 02:44   #92
Maciel Barreto
What's a Dremel?
Maciel Barreto's Avatar
Maciel Barreto has yet to learn the way of the Dremel
my project ALIENSKULL
[QUOTE=J Maciel Costa Barreto (obiwan)
city: Itajuípe - Bahia - Brazil
casemod made of zero
5 months is ready
[U]Computer Bits:[/U]
Case - Alienskull
CPU - pentium 4 3 ghtz
RAM - 2 DDR-800 4-4-4-12
GPU - 8800GTX SLI
Cooling Bits:
CPU -
GPU -
http://img56.imageshack.us/img56/4510/nea047ri8.jpg
http://img210.imageshack.us/img210/2...conceptqy3.jpg
http://img210.imageshack.us/img210/2...15992c0uk8.jpg
http://img133.imageshack.us/img133/5...sta2007nd5.jpg
Maciel Barreto is offline   Reply With Quote
Old 11th Jul 2008, 14:00   #93
petJDM
What's a Dremel?
petJDM has yet to learn the way of the Dremel
Project R1000 Redline
photos = http://petjdm.multiply.com/photos/al...ine_Photoshoot
worklog = http://www.dcwarez.net/showthread.php?t=504
modshop profile = http://www.modshop.net/users/petjdm/rig/r-1000-redline
petJDM is offline   Reply With Quote
Old 9th Aug 2008, 19:30   #94
Leo_tan
What's a Dremel?
Leo_tan has yet to learn the way of the Dremel
Bulate
http://flickr.com/photos/cza88/sets/72157606485636258/
Leo_tan is offline   Reply With Quote
Old 26th Aug 2008, 20:20   #95
vision010
What's a Dremel?
vision010 has yet to learn the way of the Dremel
My Mods so far, from old to new.
"Hitman Tribute"
"Howard the Xbox"
"ELfen Lied PS2"
"Slipknot PS2 Suite Set"
"The Neptuner Guitar Hero Guitar"
"BlueBlack Simplicity"
"All Your Base" Case
"Aether Boiler" Model One of the Aether Series
vision010 is offline   Reply With Quote
Old 6th Sep 2008, 09:50   #96
plingboot
What's a Dremel?
plingboot has yet to learn the way of the Dremel
mini-itx home server case
First post here, thought I'd share my old home server case mod
mini-itx epia 5000, 512mb, ubuntu server
Project log
And my steampunk USB stick
http://www.flickr.com/photos/limpfish/2832042079/
plingboot is offline   Reply With Quote
Old 8th Sep 2008, 10:47   #97
marcus000
Watercooling Mad
marcus000's Avatar
marcus000 has yet to learn the way of the Dremel
Akasa Omega for display at i34
  • Outside was painted Gloss Orange with a Red Flake
  • Motherboard tray was powder coated Orange
  • Opposite side panel was lasered with the Akasa logo and a window cut-out.
  • It was watercooled courtesy of XSPC.
  • This PC was on show at Multiplays i34 event earlier this year.
Full Build Log here:
http://www.watercoolinguk.co.uk/foru...ead.php?t=4149
marcus000 is offline   Reply With Quote
Old 8th Sep 2008, 10:52   #98
marcus000
Watercooling Mad
marcus000's Avatar
Silverstone TJ07 aka Project Lockdwn
  • Insides powder coated "Signal Red"
  • Outside painted White / Red Stripes
  • Right side panel lasered with Lock logo
  • Dual Loop Watercooling
Old 12th Sep 2008, 17:22   #99
WeekendWarrior
What's a Dremel?
WeekendWarrior's Avatar
WeekendWarrior has yet to learn the way of the Dremel
biohazard
my project
http://i388.photobucket.com/albums/o...wilker/134.jpg
http://i388.photobucket.com/albums/o...wilker/137.jpg
details:
http://forum.donanimhaber.com/m_25145024/tm.htm
Last edited by cpemma; 12th Sep 2008 at 18:33. Reason: One mod, one picture - Read the effing rules
WeekendWarrior is offline   Reply With Quote
Old 13th Sep 2008, 22:13   #100
Mr.TweakUp
FolieFreak
Mr.TweakUp's Avatar
Mr.TweakUp has yet to learn the way of the Dremel
This is my first post here at bit-tech, but have been reading alot on the website.
Have just posted my first vinyl project, where we cover the huge Antec 1200 case with some radical design with website logo. "no commercial" but had to start with something.
and the last together with my notebook with same vinyl theme.
See the entire project here: Folie freaks at TweakUp danish language, but alot of pictures
Mr.TweakUp is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
