Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 6th Sep 2011, 18:39   #1
FastCat
What's a Dremel?
FastCat has yet to learn the way of the Dremel
The choice of LED driver to control the RGB LEDs
Help me choose a LED driver to control the RGB LEDs (common-anode, not super bright).
There is an array (12 to 12) from the RGB LEDs.
General anodes are connected together.
The result is a common anode and the withdrawal of 144 of each color (R, G, B).
That this matter be dynamically controlled.
I still find only those - MY9221 and TLC5971 for the implementation of the topic (but am not sure that they fit me).
But perhaps there are other options ?
FastCat is offline   Reply With Quote
Old 21st Sep 2011, 00:35   #2
sammo1999
Supermodder
sammo1999's Avatar
sammo1999 has yet to learn the way of the Dremel
Hey,
The TLC5971 will work well for 16 channels providing they are indeed common anode. It will not work for common cathode.
If you have a 12 x 12 RGB LED Matrix that means you will need a minimum of 36 PWM lines (12 x 3). So you can use 3 TLC5971s and digital lines with MOSFETS to control the rows. I would go with a fast microcontroller so you get a reasonable update rate.
Did you build or buy the 12x12 RGB Matrix? I havn't been able to find a common anode RGB LED Matrix at a resonable price.
-Sammo1999
__________________
Interstellar Police Group
_________I________
_______P__G_______
Centurion: Asus A8N-SLI Premium - Athlon X2 3800 - BFG Geforce 7900 GT - 2 GB Corsair XMS PC3200 - 250GB WD SATAII - Antec SmartPower 2.0 SP-500 500W PSU - BenQ DVD+-RW - Logitech MX518 Mouse - 2x Rosewill R913E 19" LCD (Dual View)
sammo1999 is offline   Reply With Quote
Old 21st Sep 2011, 06:08   #3
FastCat
What's a Dremel?
I do 12x12x12 RGB Led Cube.
Which is already fully assembled.
It remains to consider an electronic circuit for my cube. But for me it was challenging, knowledge is not enough.
So I ask here .....
Old 21st Sep 2011, 11:40   #4
mvagusta
Did a skid that went for two weeks.
mvagusta's Avatar
mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.mvagusta is a hoopy frood who really knows where their towel is.
WOW, that's awesome
Did you buy or build that?
And what's the goal here, are you trying to make some sort of hologram effect?
mvagusta is offline   Reply With Quote
Old 21st Sep 2011, 14:11   #5
FastCat
What's a Dremel?
This RGB Led Cube I had soldered.
A light effects from it will be the same as the other rgb led cube. Video examples on the internet a lot.
Old 21st Sep 2011, 18:22   #6
sammo1999
Supermodder
sammo1999's Avatar
Yikes!
How much did it cost for the 1728 LEDS?
To control this with PWM it would probably be best to be able to control an entire row at a time (one 12 x 12 plate). This means 144 RGB LEDS which would is 144*3 = 432 individual LEDs. This means you would need 432/16 = 27 TLC5971s. This is going to be a nightmare to setup and you will still need a beefy microcontroller to control the TLC5971s.
You might want to consider using an FPGA such as the Spartan 3. Sparfun has a breakout or you could design your own PCB around one. (http://www.sparkfun.com/search/resul...&what=products)
You might want to start with a small 2x2x2 or 3x3x3 cube to play around with control methods before you buy the stuff for the monster 12x12x12 unit.
-Sammo1999
__________________
_________I________
_______P__G_______
Old 21st Sep 2011, 18:42   #7
FastCat
What's a Dremel?
All LEDs have cost me 760$.
The Internet already is ready to build the circuit RGB Led Cube 4x4x4 form and 8x8x8.
And I wanted to do something even greater
But obviously in this case have namuchalis with the development of an electronic circuit. Since want to do a minimal amount of chips that will control the LEDs.
Old 5th Jun 2016, 19:49   #8
FastCat
What's a Dremel?
My RGB Led Cube 12x12x12 (first test)
https://www.youtube.com/watch?v=ik55zT0CZiU
Old 25th Dec 2016, 07:34   #9
FastCat
What's a Dremel?
My RGB Led Cube 12x12x12 (final)
https://www.youtube.com/watch?v=1uYthfN1TCk
Happy New Year!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
