Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 4th May 2013, 11:13   #1
B NEGATIVE
All Hail Kim Jong Magoo!
B NEGATIVE's Avatar
B NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming SaiyanB NEGATIVE is a Super Spamming Saiyan
Acrylic pipebending 101
This thread is a brief how to on bending acrylic pipe and the basic use of a former.
First up is the basic kit we need.....(Magoo optional)
We have a heatgun,tube,silicone fuel line that has an OD matches the ID of the tube you wish to bend and a former....the square is for checking the 90 bends on the former.
So,the former,in this case a 2" wide piece of sheet alu rolled over a deodarant can to get a radius,you can select anything with a diameter of 40mm or over,thick walled tube will need a larger radius to prevent kinks.
The line is the bend start,this will become clear in a minute
The beauty of this is that you can form any specific angle you like and bend tube to it.
For instance: You have 2 ports you wish to join on the same plane,you can form the pathing from the inner measurement between the ports and bend a former to suit. Measure the closest points between the fittings from the actual tube insert point,bend the former so the 2 faces on the 90s match the gap and Bob is indeed your uncle
The silicone fuel line.
This needs to be around .5mm smaller that the ID of the tube you are bending
Normally used for RC cars,chosen for its high melt point and great flexibility.
The small cut line round the tube is placed at the start of you bend and is the reference point for another way of doing point to point bending.
Remember the pencil line on the former? Well,put the cut line of the silicone tube on that ref point when doing the bend and you will get consistent bend radius measurement.
Like this.
For example: I want to tube 2 ports 150mm away,inlet to inlet on the inner points,I know that a bend will have a measurement of 20mm from that mark in the fuel line to the inner wall of the radius. Knowing that,we can make the first bend using the ref point on the former,insert the tube with the mark 130mm away from the inner wall of first 90,make the bend using the ref point on the former and both inner walls will be 150mm away from each other.
The bend.
You cant see the fuel line mark but its ion line with the former ref point,this is the distance you will need to heat up ,around 100mm with the bend start 2/3 its length .
This creates a very even bend.
Hold the tube around 70mm above the heat gun on high.
IMPORTANT: Keep the tube moving,rotate constantly,do not let the heat sit in any one place.
Soon the tube will not be able to hold its own weight,this is the critical moment,too long and it will create visual anomalies and start to burn.
Now i dont have pics for the next bit as i only have one pair of hands ...
When the tube starts sag,quickly transfer to the former,matching the 2 ref points up and slowly 'form' round the radiused section,dont force it,take your time. If it starts to stiffen then re heat as required.
When you are happy with your bend then let it cool naturally,when cool you can twist the fuel line straight out with no fuss.
You should be left with this
I will be adding more on the former when Magoo finds a human lackey to do the pics.
As always,heatguns are awesome but burn stuff,be careful.
Fittings and Tube:
EK & E22 acrylic tubes come in 10mm ID and 12mm OD sizes. Both EK and Bitspower have non-compression fittings for the 10/12mm acrylic tubes.
EK and Bitspower C47 fittings are double O-Ring fittings.
Bitspower C48 fittings are skinnier and use a single O-Ring.
EK & Bitspower fittings grip really tight and you need to ensure you camber the edge of the tubes at an angle else (eg: 45deg), else you will tear your O-Rings when you put in your tubes. It helps to coat the tip of your tube in silicone grease,a thin smear will do,prior to inserting into the fittings.
You'll need to ensure your tube is seated all the way to the end and past the 2nd O-Ring.
The “seating depth” of the tube on C47 fittings is 8mm.
The “seating depth” of the tube on C48 is 4mm.
The “seating depth” of the tube on EK fittings is 9mm.
The PrimoChill acrylic tubes comes in
Inner Diameter: 3/8in.
Outer Diameter: 1/2in.
Wall Thickness: 1/16in.. This means that PrimoChill acrylic tubes and fittings are NOT compatible with EK, E22, & Bitspower tubes and fittings.
ITDiva has done some testing of other former materials and found that Buna N cord has nice properties for this method,it swells slightly when warm and shrinks when cold.
A nice alternative to the silicone currently used. As always,a former OD of 1mm less then the acrylic ID applies.
Monsoon have come to the game with a new mandrel set with everything you need with the basic technique shown above but with purpose built mandrels/formers and a new range of fittings with a novel locking technique.
The Monsoon hardline kit videos:
http://geno.boxgods.com/Hardline_Premium_Fittings.mp4
http://geno.boxgods.com/Hardline_Tools_Heatgun_Kit.mp4
http://geno.boxgods.com/Hardline_Too...nd_Measure.mp4
http://geno.boxgods.com/Hardline_Too..._Measure_2.mp4
http://geno.boxgods.com/Hardline_Cutting_Kit.mp4
This OP will be updated with a pictorial of it in use when my kit arrives.
Monsoon Kit.
The bend quality is excellent! A slight pulling motion round the mandrel makes the bend flow very well.
B NEGATIVE is online now   Reply With Quote
Old 4th May 2013, 14:05   #2
Boorach
Supermodder
Boorach's Avatar
Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.
Nice guide. Thanks for posting it.
Boorach is offline   Reply With Quote
Old 6th May 2013, 22:31   #3
chris182
Multimodder
chris182 is the Cheesecake. Relix smiles down upon them.chris182 is the Cheesecake. Relix smiles down upon them.chris182 is the Cheesecake. Relix smiles down upon them.chris182 is the Cheesecake. Relix smiles down upon them.chris182 is the Cheesecake. Relix smiles down upon them.chris182 is the Cheesecake. Relix smiles down upon them.chris182 is the Cheesecake. Relix smiles down upon them.chris182 is the Cheesecake. Relix smiles down upon them.chris182 is the Cheesecake. Relix smiles down upon them.chris182 is the Cheesecake. Relix smiles down upon them.chris182 is the Cheesecake. Relix smiles down upon them.
Thinking of trying my hand at acrylic pipes, so a great guide. Thanks! Have some rep!
__________________
Intel i7 3770k @ 4.5GHz | Corsair H100i | ASUS Z77 Maximus V Extreme | Patriot Viper 3 Black Mamba 32GB 1600MHz
EVGA 4GB GTX 670 F.T.W. | Blackmagic Decklink Quad | 512GB Vertex 4 (OS and apps)
5x 2TB Seagate Barracuda in RAID5 | Corsair Carbide 300R | 2x Noctua NF-A15 2x Noctua NF-A14 PWM
Corsair Link Commander, Cooling and Lighting
chris182 is offline   Reply With Quote
Old 12th May 2013, 14:45   #4
Editor22
E22 | Hex-Gear
Editor22's Avatar
Editor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming Saiyan
Great guide man!
__________________
Stores: E22 | HEX GEAR
Social: Youtube | Facebook
Projects: Evolution | K2 MK1 | 21
Editor22 is offline   Reply With Quote
Old 10th Jun 2013, 17:31   #5
siliconfanatic
Johny-come-Lately
siliconfanatic's Avatar
siliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyan
They really do need to sticky this... It's helped me out massivley!
__________________
Do not let anything good in life pass you by. Cherish it with all of your heart, because before you know it even life will have passed you by. And if you let all those things pass you by? The only thing filling your heart will be deep sadness and regret. So whatever you do, hold on, and never let go.
siliconfanatic is offline   Reply With Quote
Old 2nd Aug 2013, 23:47   #6
SystemiK
What's a Dremel?
SystemiK has yet to learn the way of the Dremel
Thank you so much for posting this guide! I'm going to need some large radius bends and had no idea how I was going to pull it off...I think you've saved me from going copper!
SystemiK is offline   Reply With Quote
Old 16th Sep 2013, 18:42   #7
B NEGATIVE
B NEGATIVE's Avatar
Fittings and Tube:
EK & Bitspower fittings grip really tight and you need to ensure you camber the edge of the tubes at an angle else (eg: 45deg), else you will tear your O-Rings when you put in your tubes. It helps to coat the tip of your tube in coolant prior to inserting into the fittings.
Old 21st Sep 2013, 08:35   #8
B NEGATIVE
B NEGATIVE's Avatar
Right then,I have something new to suggest as a former.
The way to fine angles as a carpenter is the use of our friend ,the Bevel.
Most bevels have the 'blade' mounted along the centerline of the tool and also have a rounded end,set your angle and form the tube round the blade and 0 block.
Much easier and endlessly reuseable.
Old 21st Sep 2013, 16:45   #9
siliconfanatic
Johny-come-Lately
By cambering the edge of the tube, do you mean chamfering the outer edge?
__________________
Old 22nd Sep 2013, 18:43   #10
B NEGATIVE
B NEGATIVE's Avatar
Yup,you must relieve the sharp edge of the cut tube before insertion
Old 22nd Sep 2013, 22:47   #11
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Super useful thread needs stickifying.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is offline   Reply With Quote
Old 22nd Sep 2013, 23:27   #12
siliconfanatic
Johny-come-Lately
Hung up the banhammer just a tad too soon, eh?.
__________________
Old 23rd Sep 2013, 00:48   #13
DarthBeavis
Supermodder
DarthBeavis can run CrysisDarthBeavis can run CrysisDarthBeavis can run CrysisDarthBeavis can run CrysisDarthBeavis can run CrysisDarthBeavis can run CrysisDarthBeavis can run CrysisDarthBeavis can run CrysisDarthBeavis can run CrysisDarthBeavis can run CrysisDarthBeavis can run Crysis
I have to re do a couple tubes had cracks from moving to and from LANS
__________________
Check out my modding blog: http://outoftheboxmods.com/
DarthBeavis is offline   Reply With Quote
Old 23rd Sep 2013, 07:45   #14
Nexxo
Whatever's Geek.
Nexxo's Avatar
No worries, I have friends who I can ask.
__________________
Old 23rd Sep 2013, 18:54   #15
KayinBlack
Toxophile
KayinBlack's Avatar
KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.
I should do this for copper since I'm bending it for KR. I should move it over and work on it.
__________________
I don't feed the trolls...
PC: Intel i7-4830K, ASUS X79 Deluxe, 64GB GEiL Golden Dragon 1333MHz RAM, EVGA nVidia Titan Black 6GB Hydro Copper, Blu-Ray burner, 4x250GB Samsung 840 EVO in RAID 10, Corsair AX860i.
KayinBlack is offline   Reply With Quote
Old 28th Sep 2013, 22:19   #16
B NEGATIVE
B NEGATIVE's Avatar
Did that one a long time a go....
http://forums.bit-tech.net/showthread.php?t=233747
EDIT: Thanks for the Sticky!
Old 12th Dec 2013, 19:57   #17
Deblow
Supermodder
Deblow's Avatar
Deblow is definitely a rep cheat.Deblow is definitely a rep cheat.Deblow is definitely a rep cheat.Deblow is definitely a rep cheat.Deblow is definitely a rep cheat.Deblow is definitely a rep cheat.Deblow is definitely a rep cheat.Deblow is definitely a rep cheat.Deblow is definitely a rep cheat.Deblow is definitely a rep cheat.Deblow is definitely a rep cheat.
Thanks for the guide, im just waiting for the cost to go down a bit
Deblow is offline   Reply With Quote
Old 28th Dec 2013, 14:45   #18
B NEGATIVE
B NEGATIVE's Avatar
OP Updated.
Old 28th Dec 2013, 22:26   #19
TekLord
Tek by Design
TekLord's Avatar
TekLord has yet to learn the way of the Dremel
Great guide. I will definitely put it to use.
TekLord is offline   Reply With Quote
Old 2nd Jan 2014, 09:53   #20
Etonia
What's a Dremel?
Etonia has yet to learn the way of the Dremel
Great guide, really useful - thanks.
Etonia is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
