Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 26th Oct 2016, 12:48   #181
Yadda
Vegan Sandwich
Yadda's Avatar
Yadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming Saiyan
Originally Posted by Byron C View Post
...But I'm still not getting any stability or adhesion issues with either of those models .
Sure, but is there any advantage to pushing the brimless printing envelope?
See 13eightyfour's post above - he adds brims to all his models and hasn't had a bad print yet.
__________________
Lost a Duff, gained a Charlie.
i5 4690k @ 4.6GHz / ASRock Z97m OC Formula mATX / 2x8GB Crucial Tactical DDR3 @ 2200MHz C10 / EVGA GTX 780 @ 1200/6400MHz / BX100 250GB SSD / Seagate 2TB SSHD / Nepton 240m AIO / EVGA 600B PSU / Corsair Carbide Air 240 / Win10 Home / 1080p monitor / Logitech MOMO wheel
Yadda is online now   Reply With Quote
Old 26th Oct 2016, 13:02   #182
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
Yes, but see also:
Originally Posted by DAVEtheRAVE View Post
Annoying that it adds post processing to trim them off but makes the world of difference.
If I print a brim every time - even when I don't need it - then that means I've got clean-up work to do after every single print. That's not really a problem on big pieces like this yarn bowl, but when I need lots of bits & pieces then that's going to get pretty old pretty quickly.
It's all a learning process, and each printer is going to have its own quirks. So far I've not had a problem with everything I've printed except for those cable chain links, and I've printed a *lot* of test objects recently (as well as some "proper" prints a while back).
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is online now   Reply With Quote
Old 26th Oct 2016, 13:05   #183
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
I like how it looks. Like some sort of composite
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 26th Oct 2016, 13:11   #184
Yadda
Vegan Sandwich
Yadda's Avatar
Yes, but see also:
Fair enough, and I agree that brims aren't always necessary. Sometimes they are though, and recognising when they might be (e.g. seeing the difference between the bowl and the boat in this regard) can save a lot of wasted time in the long run. It's just good practice but of course there are no hard & fast rules.
__________________
Old 26th Oct 2016, 13:18   #185
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Fair enough, and I agree that brims aren't always necessary. Sometimes they are though, and recognising when they might be can save a lot of wasted time in the long run. It's just good practice but of course there are no hard & fast rules.
TBH I'd totally forgotten about printing brims; when I first started getting into 3D printing it was one of those things that I learned I will probably only need on rare occasions, like rafts, so I promptly forgot about it. These cable chain links look like one of those rare occasions .
__________________
Old 26th Oct 2016, 13:30   #186
Yadda
Vegan Sandwich
Yadda's Avatar
Fair enough. The design lecturer that taught my 3D printing induction session was very keen on them and spent some time showing us examples of when they should be used.
__________________
Old 26th Oct 2016, 14:51   #187
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
I totally see the rationale; like I said, it was just something that I'd totally forgotten about in the time since I'd started learning how to use a 3D printer.
__________________
Old 26th Oct 2016, 17:41   #188
13eightyfour
Formerly Titanium Angel
13eightyfour's Avatar
13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan
I probably should have added that the brim settings I use aren't connected in any way to the actual print!
The offset is 4mm from the part, and is only used to make sure the bed is level. The quality of the video isn't great but you should get the idea. The column in the second video uses the same brim method and is 21x21x102mm and printed without issues, there are some supports in the lower section as some of the overhangs were a little too much to print without them.
I'm still getting to grips with Octoprint so sorry for the speed/quality!!
13eightyfour is online now   Reply With Quote
Old 26th Oct 2016, 18:34   #189
Yadda
Vegan Sandwich
Yadda's Avatar
Crikey Eightyfour. From one extreme to the other. Lol.
Edit: isn't a brim that isn't connected to the model called a skirt?
__________________
Old 26th Oct 2016, 18:59   #190
13eightyfour
It probably would be classed as a skirt, but shows in the Skirt/Brim options of Simplify3D so I just class them all as Brims
Edit:
That's the column before any cleanup (Just the lower supports removed) The 'fluting' is a little wobbly but nothing that a decent sanding can't fix.
Old 26th Oct 2016, 19:04   #191
DAVEtheRAVE
Supermodder
DAVEtheRAVE's Avatar
DAVEtheRAVE is a Super Spamming SaiyanDAVEtheRAVE is a Super Spamming SaiyanDAVEtheRAVE is a Super Spamming SaiyanDAVEtheRAVE is a Super Spamming SaiyanDAVEtheRAVE is a Super Spamming SaiyanDAVEtheRAVE is a Super Spamming SaiyanDAVEtheRAVE is a Super Spamming SaiyanDAVEtheRAVE is a Super Spamming SaiyanDAVEtheRAVE is a Super Spamming SaiyanDAVEtheRAVE is a Super Spamming SaiyanDAVEtheRAVE is a Super Spamming Saiyan
Brims trim off easily enough with a good craft knife, but yes they are a pain and so I only do them if I'm concerned about a small contact area.
Isn't a brim that isn't connected to the model called a skirt?
Yup
Edit: beaten to it!
__________________
Main: Gigabyte Z87X-D3H . Core i5 4670K 3.4GHz . EVGA GTX970 ACX SC . Corsair Vengeance 16GB . Crucial MX100 256GB . Seagate Barracuda 2TB . Corsair HX620 . Lian-Li PC7B plus . Dell U2412M . Samsung SM226BW . Ducky Zero MX Reds
HTPC/Server: ASRock C70M1 . Asus GT 630 . GSkill RipJaw 4GB . Crucial BX100 64GB . 2x Seagate NAS 2TB . Silverstone Strider Plus
Laptop: Microsoft Surface Pro 4 . i7 . 500GB
Steam: SkiDave
DAVEtheRAVE is online now   Reply With Quote
Old 26th Oct 2016, 19:25   #192
Yadda
Vegan Sandwich
Yadda's Avatar
*Snip*
Yes, it definitely is a skirt, lol.
I think you've invented a thing - "extreme brimless 3d printing".
Edit to add:
I'm getting to grips with Fusion360 and I'm well on the way to producing a virtual model of my prototype, to scale. It's a lot easier than I imagined it would be and I'm really enjoying it. I'm currently researching the best way to create a reverse/inverted fillet to a specified arc. So-far the best way seems to be to draw a circle to the necessary radius, position it, and trim the excess. All good fun and just a bit amazing.
__________________
Old 26th Oct 2016, 19:44   #193
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Printing with a skirt is definitely a good idea, as it builds the correct pressure in the extruder and gets the filament flowing properly before the print starts.
In other news: this finished
The surface pattern was a total error on the part of the designer, but I quite like the look. Doesn't look anywhere near big enough to fit a ball of wool into but the other half hasn't even tried using it yet. More importantly it's the biggest/longest print that I've ever done and I'm really happy with the results - there are none of the problems that I used to get in my prints. Calibrate your extruder, people!
Next task: get Cura working, copy the settings over from Slic3r, hope I get the same good results from Cura as I currently do with Slic3r, then get OctoPi/OctoPrint running on a Raspberry Pi. Of course I can't use a recent version of Cura to do this of course, that would be too easy: the version of CuraEngine shipping on OctoPrint doesn't support the JSON settings format from newer versions of Cura, only the older INI format.
__________________
Old 26th Oct 2016, 19:52   #194
Yadda
Vegan Sandwich
Yadda's Avatar
Aye. Skirts, brims, rafts. They're there for a reason and all have their place.
The wool holder's looking good! Nice one.
__________________
Old 27th Oct 2016, 00:27   #195
Yadda
Vegan Sandwich
Yadda's Avatar
Here it is, my first Fusion 360/3d printing scratch design, rendered in all its glory.
I'll get it printed on Friday when I'm next at the college-of-knowledge.
What a fantastic tool Fusion 360 is, I can't wait to get this made and give it a try!
__________________
Old 27th Oct 2016, 12:04   #196
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
It seems I take two steps forward and then one back...
That's the brim being pulled up off the bed...
Nice!
__________________
Old 27th Oct 2016, 12:17   #197
veryevil
Ultramodder
veryevil's Avatar
veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.
Whats your bed made of?
I really swear by glass with hair spray. I just simply do not get any lift with PLA.
My printer is an Ormerod 2 with PCB heated bed, Aluminium heat spreader and then a sheet of glass.
__________________
My Rig: [Intel i5 4690s] [MSI Gaming 3] [EVGA Geforce 970 FTW+] [Corsair Vengeance DDR3 2400Mhz 4 x 4GB] [Corsair HX850W Professional] [Corsair Carbide Air 540]
veryevil is online now   Reply With Quote
Old 27th Oct 2016, 12:22   #198
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
It's an aluminium bed lined with masking tape. The only time I ever get lifting problems is with these damn chain links.
__________________
Old 27th Oct 2016, 12:33   #199
Goatee
Hypermodder
Goatee's Avatar
Goatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming Saiyan
Possibly a daft question but are the chain links flat against the bed in the slicer?
Goatee is offline   Reply With Quote
Old 27th Oct 2016, 12:43   #200
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Not a daft question at all
Yes they are, but on closer examination I did notice this:
A very slight fillet to the bottom edge. That can't be helping matters... I've just flipped the model 180 along the X axis, so the flat "top" layer is now against the bed. Let's see how this goes now...
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
