Old 17th Aug 2015, 09:29   #1
GatheringStorm
What's a Dremel?
GatheringStorm has yet to learn the way of the Dremel
Scan more like Scam
I wrote a thread yesterday about feeling scammed by Scan , i notice this thread was not allowed on here. So Bit Tech pick and choose what they feel right to be seen by public. Disappointed as thread is very much relivent to things. I bought a motherboard bundle from Scan and when pacakge arived i found only a heat sink in processor box. Scan being Scan claim it impossible there end to make mistake, Seem 4 + people check and double check packaging. Yet it known fact humans make mistakes fromn time to time. yet they will not comprehend this.
GatheringStorm is offline   Reply With Quote
Old 17th Aug 2015, 14:10   #2
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
If you worded your post in a more reasonable manner you would probably get a better response.
Also, you are new around here, so this is especially important. Imagine being at a party, then someone nobody knows bursts through the front door and starts mouthing off. Doesn't go down too well does it.
__________________
Ediface
Silverstone FT03 Mini - i7 4790S - Noctua NH-L9i - Gigabyte GTX 1070 'ITX Edition' - Maximus Impact VII - 16GB DDR3 - 1TB NVME - SF600 - 27" AOC Agon AG271QG - Xonar U7 - Bassshaker - RAT3 - Majestouch Minila - Q90s - Orbweaver - Warthog
Parge is online now   Reply With Quote
Old 17th Aug 2015, 14:28   #3
goldstar0011
Mod Master
goldstar0011's Avatar
goldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyan
Welcome to the community, start as you mean to go on I guess.
Never saw the thread but look at it from their POV, you could be scamming them just like you're accusing them, civil communication would help things along.
I do hope Scan look into this properly for you though, like you say, humans make mistakes.
goldstar0011 is online now   Reply With Quote
Old 17th Aug 2015, 19:20   #4
GatheringStorm
What's a Dremel?
Given i wrote thread other day explaining my experince with scan and then found moderator never posted it , you be angry to , and i think you would find i worded things perfectly in that post if you got to see it
Old 17th Aug 2015, 19:22   #5
GatheringStorm
What's a Dremel?
okay i notice this thread is up now , Below this one , my appolgise but i was angry becase i thought my post wasent being accepted on forum. As you see i worded things fine on it
Old 17th Aug 2015, 19:55   #6
bawjaws
Mod Master
bawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyan
I can see your original thread directly below this one. I suspect that what's happened is that your original post was your first on these forums and that as a result it went into the moderation queue, so took a day or so to appear.
So no-one is trying to suppress your opinions or concerns, as far as I can see...
Anyway, welcome to the forums and I hope you get your situation resolved to your satisfaction. I should say that in the past I've received items from Scan in packaging that wasn't sealed and when I queried this was told that Scan sometimes open boxes to check the contents or record serial numbers. That was a good few years back, mind.
bawjaws is online now   Reply With Quote
Old 18th Aug 2015, 09:59   #7
mark@scan
Technical / Returns Manager
mark@scan's Avatar
mark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyan
Hi John,
This case is still under investigation by Dawn the customer service manager who will be in contact later today with an update.
Regards
mark@scan is offline   Reply With Quote
Old 18th Aug 2015, 11:18   #8
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
@OP - we're all very busy IRL at the moment. It's not about censorship, it's about time.
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
