Old 19th Nov 2015, 01:45   #1
TaZ
Minimodder
TaZ's Avatar
TaZ has yet to learn the way of the Dremel
8 Pin extension change
Hi, just trying on here as it's out of hours on the off chance someone sees it before tomorrow morning, when I will call the shop anyway to see about this issue (I work nights, so quite awkward doing things during business hours)
I bought the following yesterday LN49002 - http://www.scan.co.uk/products/silve...sion-cable-red
as my power supply isn't quite long enough to go behind the MB tray and back over in my new Enthoo Pro case. However, the left hand 4- in of my PSU cable only goes half way into the female end of the above cable. The right hand 4-pin goes all the way in no problem. I can't see any bent pins on either the extension or the PSU cable, and after it wouldn't fit into the extension I re-routed it back over the GPU and it plugs straight into the MB no problem, so I feel the extension is the issue.
If I bring it back can you exchange it for another?
Also on the same order, I bought a 6-pin extension cable (wrongly) for my GPU whilst having a brain fart, only to realise when I got home I needed a second 8-pin extension. The 8-pin and 6-pin extensions are the same price; I haven't opened the 6-pin packaging, would I be able to do a straight swap for another 8-pin extension?
Regards,
David
TaZ is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
