Old 12th Feb 2016, 12:37   #1
stealth80
Supermodder
stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.stealth80 is definitely a rep cheat.
RMA Tracking
Hi, firstly I wanna say that this is more of a query than a complaint. I bought an Asus RoG PG287Q a couple of weeks ago and it turned out it was faulty on arrival. I sent a message to Scan accompanied with a video of my symptoms and it was quickly followed by an RMA number and collection instructions. It was delivered to Scan on Tues 9th Feb (I found this out after emailing directly).
My problem is for some reason I can not track my RMA in the RMA tracker, it just comes back with an error message saying that the RMA can not be found.
RMA is 384670
Thanks
__________________
Project Temporal Snow - http://forums.bit-tech.net/showthread.php?t=314299 - In Progress
Temporal Snow Ryzen Refresh https://forums.bit-tech.net/showthread.php?t=323038
Ryzen 1700 @ 4.0 GHZ - Gigabyte AX370 Aorus Gaming 5 - 16GB GSkill Trident RGB 3200 MHZ - Palit 1080 GTX Gamerock Premium - Samsung XP941 256GB - Crucial MX300 525GB - Fractal Design R3 Newton 1000w White Edition
stealth80 is offline   Reply With Quote
Old 12th Feb 2016, 13:18   #2
davidm
Multimodder
davidm's Avatar
davidm is a Super Spamming Saiyandavidm is a Super Spamming Saiyandavidm is a Super Spamming Saiyandavidm is a Super Spamming Saiyandavidm is a Super Spamming Saiyandavidm is a Super Spamming Saiyandavidm is a Super Spamming Saiyandavidm is a Super Spamming Saiyandavidm is a Super Spamming Saiyandavidm is a Super Spamming Saiyandavidm is a Super Spamming Saiyan
Have just tested this myself - and using the RMA number and invoice number, it works fine.
Please just enter the actual numbers themselves. Sometimes people do enter "RMA 12345" instead of "12345"
davidm is offline   Reply With Quote
Old 12th Feb 2016, 14:29   #3
stealth80
Supermodder
Hi thanks for the response, I just tried again and got the same message:
I used the same invoice number as you see on this post.
Thanks
__________________
Old 12th Feb 2016, 14:31   #4
stealth80
Supermodder
Ok I just tried using Chrome rather than Microsoft Edge and it worked fine, obviously another bug with Edge.
Thanks again
__________________
Old 12th Feb 2016, 14:37   #5
davidm
Multimodder
davidm's Avatar
I'll let the web team know about this - glad you got it working.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
