Old 30th May 2016, 09:28   #1
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
A big thank you
Just wanted to say thank you to Olivia and Carrie who helped me with my RMA.
Process was painless and I have my replacement item and it arrived undamaged.
Cheers.
__________________
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX 1080 Ti SLI; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Scorpuk is offline   Reply With Quote
Old 15th Jun 2016, 11:32   #2
mark@scan
Technical / Returns Manager
mark@scan's Avatar
mark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyanmark@scan is a Super Spamming Saiyan
Thanks for the feedback, I will be sure to pass on your thanks to Olivia and Carrie in our customer service team
Regards
mark@scan is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
