Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 26th Sep 2016, 11:36   #1
phinix
RIP Waynio...
phinix's Avatar
phinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyan
CNC service needed (simple cuts with CNC router) UK
Guys, I need to cut something simple on CNC out of 10mm and 3mm acrylic sheet.
For years Tom from chilledpc was doing it for me. 6 months ago I sent him acrylic sheets to do these. He never replied, I contacted him numerous of times. Its been 6 months now he hasn't replied and I need to finish my project now and need this done.
I'll add images of those bits soon, it is simple 20x20cm acrylic square that needs inside bits to be cut out. Like a frame from square. 10mm thick black acrylic sheet.
Second thing is to cut from 3mm acid green acrylic A4 sheet some small bits.
Is there anyone in UK with cnc router could help meout?
__________________
7500|1080Ti|2x 500GB SSD|2TB HDD|Z270 ITX|16GB RAM|SFX 600W|Philips 40" 4K BDM4065UC
2x Novatouch|Varmilo VA69M greens|Zowie EC2 Evo|X52 PRO|DK2
::: Phinix Cube ::: Phinix Nano Tower ::: Phinix Aurora ::: Phinix Chimera ::: Phinix Retro :::
star citizen ::: CMDR Phinix 325A LTI
phinix is offline   Reply With Quote
Old 1st Oct 2016, 13:49   #2
phinix
RIP Waynio...
phinix's Avatar
I'm sure someone has cnc router on our forum.
Or does anyone know good company who does cnc routing?
__________________
Old 1st Oct 2016, 14:51   #3
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Ask our forum member Skyrip, who did some excellent work for my project (in sig). He lives in the Netherlands but that does not affect postage or turnaround time much.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is offline   Reply With Quote
Old 1st Oct 2016, 15:27   #4
phinix
RIP Waynio...
phinix's Avatar
I shall ask then! Thanks for a tip
__________________
Old 24th Nov 2016, 22:50   #5
HackJoe
Hypermodder
HackJoe's Avatar
HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.
E22 buddy! I know they have a CNC machine, not sure if it's currently set up (they moved). But the service if listed on their site, so it could be worth a crack.
LINK
J.
HackJoe is offline   Reply With Quote
Old 26th Nov 2016, 14:03   #6
phinix
RIP Waynio...
phinix's Avatar
LINK
J.
Thanks. I will ask Nate about it.
I also asked him about cutting old case.
__________________
Old 31st Jan 2017, 17:11   #7
LePhuronn
Modder
LePhuronn's Avatar
LePhuronn has yet to learn the way of the Dremel
Does it have to be CNC? If you're just cutting shapes then there's plenty of laser cutting companies out there.
Jump on RazorLAB and have a look at their materials selection, and they can order in stock if you want something specific - upload an AI or EPS file based on their specs and their system (which is essentially a Ponoko system) will give you a quote.
I'm actually about to use LaserLea in Manchester because they were cheaper for some 1.5mm thick stuff.
LePhuronn is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
