Old 30th Sep 2016, 10:08   #1
DwarfKiller
Multimodder
DwarfKiller's Avatar
DwarfKiller has yet to learn the way of the Dremel
RMA issues on invoice 00e2856808
Bought a PSU to replace a dead unit, replacement turned out to be DoA.
I have 3 sets of components available for testing and confirmed it dead on all 3. I confirmed all 3 sets
working with another supply. It also failed a pin test.
The issue? RMA refused due to no fault found.
"Used the PSU to power Test Bench 11 using an Nvidia GTX770. Powers up fine, ran Heaven benchmark for a few mins with no issues. NFF"
I have since reconfirmed all 3 sets as working due to the notification.
Could I get an explanation? If no RMA is being issued I would like to pursue a refund and purchase elsewhere.
__________________
i7 930 @3.8 + Titan Fenrir | Asus P6T SE | HD5870 PCS+ | Corsair XMS3 Classic DDR3 @1600 | CM690-II Adv. | 750W Seasonic-X |
DwarfKiller is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
