Reply
Thread Tools View Mode
Old 5th Apr 2017, 15:34   #21
davido_labido
Staff
bit-tech Staff
davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.
Excellent progress on this build!
We have added it to our March Modding Update Here!
The winner of the Modding Update gets some nice Corsair fans
davido_labido is offline   Reply With Quote
Old 5th Apr 2017, 20:35   #22
InsolentGnome
Supermodder
InsolentGnome's Avatar
InsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming Saiyan
Thanks Dave!
Dave
BTW, great name!
__________________
Current Projects: The Gunslinger - CM Mastercase5, Crimson King - CM Mastercase5
Past Projects: Spark, F3, Shinai, Scout, Gigantea, Rehab, Twelve-80
For more randomness, check out my tweets or my face page or my website!
InsolentGnome is offline   Reply With Quote
Old 12th Apr 2017, 02:30   #23
InsolentGnome
Supermodder
OMG! Does wiring ever end???? Apparently not, but I have made some progress. Extensions, sleeved.
But before we get into running the fans, I need to do something about the power and reset buttons. Although I like having I/Os on the front of the case, I hate the mess you have to deal with on the inside, especially in a mod, so they've got to go to be replaced by a simple power and reset button pair. First off I need to make a plate to cover the original I/O plate. Using a pencil lead, I rubbed the outline onto some paper.
I could then cut that out and transfer the shape over to some 1mm Al to cut out.
Then some mounting holes to hold the Al to the original plate and while I was at it I notched the plate out with a dremel to allow my switches to run through.
Voila! Switches! Even the case is excited about it! :P
I'm painting the plate to match the rest of the case and the switches are white LEDs to match the color scheme.
While I was playing around with the wire, I managed to have my X-Carve die on me. At first I thought it was a stepper, but it turned out to be a shorted wire so after working that out, I could start milling out a few symbols in the back plate that relate to the stories. Everything started out fine.
But two broken bits later I decided that this piece of Al wasn't having any of it. It wasn't chipping very well and I'm not really sure why. I've never had this problem with these settings on 6061 or 5052 Al before, so I decided to ditch that back panel and make a new one out of some 5052 I had laying around. Three benefits to this, I just milled the same design in a piece of 5052 with no trouble, the 5052 will bend nicely for the GPU bracket on this new panel vs. the cracking that happened on the first panel, and I know what the hell I'm dealing with. I'm pretty sure the original panel was 6061, I can't imagine what else it would be, but I also had to do some brazing on it when the GPU mount cracked, so maybe the heat was enough to screw with some of the properties of the panel? No clue, but I busted out the new panel using the original as a template and the milling went smooth as butter.
One more design to cut above the I/O shield and this baby is ready for a test fit and paint.
And speaking of milled parts, I just got some awesome milled parts in for the cooling loop.
MNPCTech 1/2" hardline fittings. A bunch of them! Can't wait to get these babies in and start planning the loop.
And a big thanks to my sponsors:
and now,
__________________
Old 13th Apr 2017, 15:56   #24
InsolentGnome
Supermodder
Back panel, milled, sanded, and ready for paint.
So there's one thing that any self respecting Dark Tower build needs, and that's a rose. The Dark Tower is surrounded by a field of roses and in one of the multiple worlds, there exists a rose that is the tower's counterpart. So rose=important. I had thought about putting a rose in the back panels, but liked the idea of Ka and the siguls of the King and the Deschains better. So another place that was begging for a little love was the grill cover on the top panel. It's kind of bland and boring up there and I'm hoping that the LED fans shining up through a silhouette will look pretty cool.
ABS on an X-Carve is like going through butter with a hot knife. A nice change from dealing with aluminum, and probably a whole lot better than what is coming up, a steel side panel. Not really sure how that one is going to work out. But I got a nice vector drawing of a rose, set it all up, and let it eat.
I taped the hell out of the first one to keep stuff from flying around and was a bit scared of breaking something taking it up, so the next one I went easy on the tape. That was a mistake as one of the thinner sections let go and garbled the design. Not bad and I could live with it, but I'm still going to look into a replacement.
Sponsored by:
__________________
Old 19th Apr 2017, 05:48   #25
InsolentGnome
Supermodder
With the back panel ready for paint, let's look at how I painted them, since it doesn't really show in the pics.
First up is a a coat of rattle can black over primer.
It's got a bit of orange peel but that won't really matter. Next is a medium scratch pad to rough up the surface so that the next layer has something to grab on to.
The top coat is a textured paint from Rustoleum that's supposed to look like rock??? Kind of? It really isn't bad and basically turns the finish into coarse sandpaper.
It's not the slate brick that's in the story, but it looks kind of rocky. One nice thing is that as long as the base was black, it all pretty well matched, so I just top coated the parts of the case that didn't need paint and it matched the parts I painted black just fine. Another is it'll cover blemishes in the base and doesn't scratch unless you really go at it.
With the back panel done, it was time to start putting it all together.
Wired up the switches and the fans.
And did some weathering to make the back side wiring look older.
Then the mb went in. I like having the wire running under the board, but it can be a pain to get it laying right. Still need to add some combs to clean it up.
And the back panel was riveted on.
I went with white LED's to light the interior and help show off the details.
And the GPU finishes off the hardware.
And a few shots with it's antagonist.
Now the loop is the only thing left to finish!
Sponsored by:
__________________
Old 25th Apr 2017, 05:18   #26
InsolentGnome
Supermodder
Ah the fun part, the loop.
Nothing too crazy here running clear 1/2" od Primochill PETG in between Bill's hardline fittings. I do have one of the measuring and bending sets from Monsoon, but find that I actually get better results just bending by hand. I tackled the res first. The bottom bend was tricky, 3 bends, 3 planes, and no way to hold the piece in position to eyeball it. Heck I could barely get the finished piece in since it had to go through a slot under the rad just over 1/2" tall.
Once the hard bend was out of the way, the rest was just figuring out what looked best. Ok, I'll admit that it wasn't that easy. I spent a few days looking at it and deciding where i wanted the lines to run, but once the planning was out of the way, running the loop was a matter of a couple of hours.
The big thing was making sure everything was straight.
And then I filled the loop with Mayhem's UV white pastel. I really only wanted white but ordered the UV by mistake. Oh well, it'll look cool in black light, LOL.
Yeah, that run from the CPU to GPU is off. Sometimes you've got to get the fluid in to really get an idea of what it looks like. I thought it would be passable before I filled it, but wound up draining the loop to re-bend that piece.
While I was working on the loop, I was also cutting acrylic side panels.
They still need a bit more work but are passable. I thought I had the holes for the magnets figured out, but wound up having to glue them in instead press fitting them. That was a bit of a pain.
But now we're ready for final shots!
Sponsored by:
__________________
Old 26th Apr 2017, 02:02   #27
InsolentGnome
Supermodder
And now we're at the end of our journey. I want to thank GeForce Garage, Swiftech, and MNPCTECH for sponsoring this build and it's twin. They really made these possible. Also, I know a lot of people don't know the story these cases are based on, but hopefully they're cool enough to still be appreciated. Now on with the pics!
Once again, a big thanks to my sponsors:
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
