Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 23rd Dec 2016, 00:03   #1
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
Getting US imperial nuts/bolts in the UK
I decided to start building a 3D printer which is sized mostly in backwards US units. I didn't think it would be too difficult to adapt the design to sensible metric units, but I didn't check the full BOM in any great detail. Now that I've started the build and already printed ~300g of parts, I realise that I should have checked the amount of fasteners listed in the BOM. Oops.
In case I give up on trying to source metric equivalents, can anyone recommend a UK/EU supplier that sells imperial fasteners? Preferably I'd like to avoid paying an arm and a leg.
There's quite a range of nuts/bolts I need, and I haven't been able to find a single supplier which can do the lot (full list in BOM - I'm making the printed version, so need the extras). For example: I've found a couple of places that supply 10-32 socket head screws, but the same places do not also sell 8-32 socket head screws...
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is online now   Reply With Quote
Old 19th Jan 2017, 22:17   #2
Dr. Coin
Supermodder
Dr. Coin's Avatar
Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.
Any luck finding imperial sizes in the UK?
__________________
Wait, I’ve got an idea, and it doesn’t require high explosives.
-Sam & Max Hit the Road
Dr. Coin is offline   Reply With Quote
Old 19th Jan 2017, 23:09   #3
ferret141
Ultramodder
ferret141's Avatar
ferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyan
My go to site Tizaro is no more
Is fleabay too expensive?
__________________
i5 2500K | Thermaltake Frio | 2x4GB Corsair Vengeance LP | ASUS P8P67 Pro | EVGA GTX680 2GB SC Signature 2 | Corsair AX1200 | 256GB OCZ Vertex 4 x2 R0 | 2TB WD Caviar Black | 3TB WD Red | SONY-NEC BD-5300S BD-RE | Silverstone Raven 2 Evolution (RV02E-BW USB3.0) | ASUS VG278H 3Dv2 | Win7 Ult. 64bit | Creative X-Fi Fatal1ty Platinum Champion Series | Speakers:Logitech G51 | Headset:Beyerdynamics DT770 Pro + ModMic 4.0 | Keyboard:Logitech G15 | Mouse:Logitech G9x
Plusnet | Loadout
ferret141 is offline   Reply With Quote
Old 19th Jan 2017, 23:16   #4
Big Elf
“not another f—-ing elf”
Big Elf's Avatar
Big Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming SaiyanBig Elf is a Super Spamming Saiyan
Modelfixings?
__________________
Case Labs TH10│Asus Rampage III Extreme│Core i7 990X│24GB Corsair Dominator GT│GTX Titan SLI│Samsung 850 EVO 256GB│Crucial M4│2TB Samsung Momentus x 2│SeaSonic P1000W│EK Supremacy│EK FC-RE3│EK-FC Titan SE x 2│EK-RAM Dominator│Black Ice SR-1 480 x 3│Swiftech 35X2
Big Elf is online now   Reply With Quote
Old 20th Jan 2017, 06:35   #5
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
And obviously there are sellers on Amazon too. Maybe not the exact head type listed there, but oh well. It's mostly the "sourcingmap" seller, might be worth to look at them and maybe even ask for the ones they do not sell on Amazon, they might be able to source them :
https://www.amazon.co.uk/sourcingmap...dp/B00W982CPM/
https://www.amazon.co.uk/Alloy-Socke...dp/B00PZO4MZA/
https://www.amazon.co.uk/Alloy-Socke...dp/B00PZM31K4/
https://www.amazon.co.uk/sourcingmap...dp/B0143DZQ6W/
faugusztin is online now   Reply With Quote
Old 20th Jan 2017, 11:51   #6
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Thanks all, links noted.
This project has been sort of put on hold anyway while I sort through some personal stuff.
__________________
Old 23rd Jan 2017, 00:14   #7
LePhuronn
Multimodder
LePhuronn's Avatar
LePhuronn has yet to learn the way of the Dremel
everything's on eBay, specifically a seller called Kay's Fasteners. Look them up once your personal stuff is sorted (all the best with that too)
LePhuronn is offline   Reply With Quote
Old 4th May 2017, 10:38   #8
MrJoosh
What's a Dremel?
MrJoosh has yet to learn the way of the Dremel
There is a place near me called Rothwells that deal in all manner of fixings and stuff, and they are really helpful guys... Also, surprisingly cheap compared to FleaBay/Amazon etc... (I recently bought ~200 M6 Allen head bolts, nylock nuts and washers, and came to roughly £3)
The other option could be Bapp for Bolts as they specialise in bolts and fixings etc...
Hope this helps, and that your personal stuff sorts itself out
Josh
MrJoosh is offline   Reply With Quote
Old 4th May 2017, 16:49   #9
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
You guys really don't have hardware stores with an entire isle dedicated to fasteners?
-Holy sh*t. I just web searched an Ace hardware in London. They didn't even have a nail.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 4th May 2017, 16:56   #10
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Yeah we do. They just have proper measurements in millimetres, rather than eigths and sixteenths . The project I intended this for is measured in imperial, so I just wanted to be sure that I could find the right parts in case there's no metric equivalent.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
