Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 9th Jan 2017, 17:13   #1
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
NCASE Mod. As yet untitled (and very much a WIP...)
So - I've been kicking this one around for a while, and thought if I posted something on bit, it would make me actually pull my finger out and do something about it.
I've got my trusty NCASE that I want to shoehorn my current #1 system into, complete with a full WC loop. It'll be total overkill, and as you probably know, I like making computers that are small (and quiet).
I suspect this won't be anything near silent, but still.
The biggest problem I'm facing is the location of pumps and reservoirs. I've seen a few versions of water-cooled NCASEs recently, which either house the pump and res outside, like this one:
...and FrozenQ even make an exterior reservoir for the M1:
I don't want to do that. There's 'dead' space in the front between the pop-on front panel, and I reckon there's wasted space under the top panel too.
This gives me an idea...
I'm aiming for a 45mm(ish) rad in the side and a 30mm rad in the bottom (with thin fans) to cool a 5960X, a Titan X (Pascal), and maybe the RAM if I can fit in a RAM block for funsies.
So I suppose, the specs will be:
- Asrock X99e/ITX
- nVidia Titan X Pascal
- Samsung 950 Pro 512Mb
- Corsair SF600 PSU
- 32Gb Crucial Ballistix DDR4
- 1Tb 850 EVO
...and in terms of watercooling:
- Bitspower Full Cover ASRIX99 block
- Aquacomputer Titan X Block plus active cooling backplate
- EK rads (for now)
- as yet undecided pump
- as yet undecided fans
- hard tubing? don't know yet.
I'll be doing custom cables for it too.
My thinking is perhaps fitting a custom-fit res into the front (in the void), but pump location is currently bothering me.
Anyway - initial ramble over. I'm going to go away to do some thinking and planning.
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is online now   Reply With Quote
Old 9th Jan 2017, 20:11   #2
Goatee
Hypermodder
Goatee's Avatar
Goatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming SaiyanGoatee is a Super Spamming Saiyan
Do you need a Res? Can you go old school T-Line?
Goatee is online now   Reply With Quote
Old 9th Jan 2017, 20:29   #3
jinq-sea
Moderator
jinq-sea's Avatar
I'm thinking combo res and pump top in the front of the case - I'm busy scheming some 3D models!
__________________
Old 9th Jan 2017, 21:35   #4
Goatee
Hypermodder
Goatee's Avatar
3d printing them?
Would an XSPC ion fit?
Old 10th Jan 2017, 00:42   #5
23RO_UK
Hasta Maņana
23RO_UK's Avatar
23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan23RO_UK is a Super Spamming Saiyan
Here's a link Jinx LINK
As per Goatee's suggestion it looks like a nifty bit of kit
Edit:- Review LINK
23RO_UK is offline   Reply With Quote
Old 10th Jan 2017, 08:38   #6
jinq-sea
Moderator
jinq-sea's Avatar
I've already got one of those - it's excellent - in fact it's brilliant for a SFF build - thanks both
However - I've got some custom acrylic ideas brewing - watch this space!
__________________
Old 10th Jan 2017, 20:47   #7
Arboreal
I *am* a Dremel
Arboreal's Avatar
Arboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming Saiyan
Jinqs, brilliant stuff! Someone on BT attacking an M1 at last
There haven't been enough brave people chopping into them yet...
(Insert meme of bearded man opening camping chair here)
Arboreal is online now   Reply With Quote
Old 11th Jan 2017, 13:12   #8
Hitman
Ultramodder
Hitman's Avatar
Hitman is a Super Spamming SaiyanHitman is a Super Spamming SaiyanHitman is a Super Spamming SaiyanHitman is a Super Spamming SaiyanHitman is a Super Spamming SaiyanHitman is a Super Spamming SaiyanHitman is a Super Spamming SaiyanHitman is a Super Spamming SaiyanHitman is a Super Spamming SaiyanHitman is a Super Spamming SaiyanHitman is a Super Spamming Saiyan
Nice, really tempted to pick up an NCASE. I'm between that and one of the new Caselabs Bullet's. Will be interesting to see how you fit that all in the NCASE
edit - can I just ask if you dont mind, did you get hit with much import cost on the NCASE?
Hitman is online now   Reply With Quote
Old 11th Jan 2017, 15:18   #9
jinq-sea
Moderator
jinq-sea's Avatar
They're really great - now there's a decent wave of SFF PSUs from which to choose.
I can't remember how much import duty I got 'done' for - could probably find the paperwork though! I will probably end up ordering some more bits from them anyway - as I could do with a couple of spare panels...!
__________________
Old 11th Jan 2017, 15:28   #10
Hitman
Ultramodder
Hitman's Avatar
Ah don't worry about it
Old 18th Jan 2017, 11:50   #11
jinq-sea
Moderator
jinq-sea's Avatar
So - work has got in the way of my planning and scheming over the last week, but I now have a head full of ideas. Now to get them on paper...
__________________
Old 18th Jan 2017, 19:56   #12
Arboreal
I *am* a Dremel
Arboreal's Avatar
Comeoncomeoncomeon, get on with it then, we're all here sitting down with the popcorn waiting...
Old 19th Jan 2017, 08:41   #13
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
If your WC isnt internal you're cheating.
Mankz is offline   Reply With Quote
Old 19th Jan 2017, 09:19   #14
jinq-sea
Moderator
jinq-sea's Avatar
It will be, fear not!
__________________
Old 19th Jan 2017, 12:24   #15
Arboreal
I *am* a Dremel
Arboreal's Avatar
Phew! That's a relief
I agree with Mankz on that point
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
