Reply
Thread Tools View Mode
Old 18th Apr 2017, 19:37   #81
MPC
Multimodder
MPC's Avatar
MPC has yet to learn the way of the Dremel
Sleeving with Gosumodz high quality materials.
MPC is offline   Reply With Quote
Old 19th Apr 2017, 19:08   #82
MPC
Multimodder
MPC's Avatar
Create a hole in the top to manage the cables and the led inside the clock reservoir. The hole will be filled with glue to make the reservoir waterproof.
Old 19th Apr 2017, 20:20   #83
Dr. Coin
Supermodder
Dr. Coin's Avatar
Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.
I am curious to see your wire combs in action, unusual shape.
__________________
Wait, Iíve got an idea, and it doesnít require high explosives.
-Sam & Max Hit the Road
Dr. Coin is offline   Reply With Quote
Old 20th Apr 2017, 08:10   #84
MPC
Multimodder
MPC's Avatar
Yes, it's a new shape to lock the 24-pin and 8-pin cpu cables on the plexiglass wall.
Old 20th Apr 2017, 20:31   #85
MPC
Multimodder
MPC's Avatar
Cutting steel inox cables to fix the clock with the basin.
Old 21st Apr 2017, 12:00   #86
GravitySmacked
Mostly Harmless
GravitySmacked's Avatar
GravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming Saiyan
Coming on beautifully; I can't wait to see it all put together!
GravitySmacked is offline   Reply With Quote
Old 21st Apr 2017, 14:21   #87
MPC
Multimodder
MPC's Avatar
Thank you very much Gravity
Old 23rd Apr 2017, 19:46   #88
MPC
Multimodder
MPC's Avatar
Equipment the bulkhead connector whit o-ring to obtain cooling liquid in the basin. Using of bolts to block the electric motor and the main mechanism. Using of waterproof bearing.
Old 26th Apr 2017, 19:07   #89
MPC
Multimodder
MPC's Avatar
Luxury computer storage system.
Old Today, 16:37   #90
MPC
Multimodder
MPC's Avatar
Many thanks to Aquatuning that sent me extra- material when I was working for the project.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
