Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 22nd Feb 2017, 22:31   #1
LePhuronn
Multimodder
LePhuronn's Avatar
LePhuronn has yet to learn the way of the Dremel
UK members making their own PCBs
Hi
As per the title, are there any UK-based members making their own PCBs? I'm toying with the idea of doing some small circuits to help with some power wiring for my Asteria II project and fancied something a bit fancier than veroboard.
One of them would be a simple 3-way splitter for PWM fans, the other would be to split off a couple of SATA power connectors for some drives and LED strips.
Give me a shout if anybody's around.
Cheers
__________________
Project: ASTERIA II: Rearmoured
In Win 901, case mod, watercooled | Modding update nominee April 2017
LePhuronn is offline   Reply With Quote
Old 23rd Feb 2017, 07:44   #2
veryevil
Ultramodder
veryevil's Avatar
veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.veryevil is definitely a rep cheat.
http://dirtypcbs.com/store/pcbs
__________________
My Rig: [Intel i5 4690s] [MSI Gaming 3] [EVGA Geforce 970 FTW+] [Corsair Vengeance DDR3 2400Mhz 4 x 4GB] [Corsair HX850W Professional] [Corsair Carbide Air 540]
veryevil is online now   Reply With Quote
Old 23rd Feb 2017, 08:59   #3
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
I've designed a few. Dirty PCBs is good, as per veryevil's recommendation, but if you want stuff on a quick turnaround and made in the Good Ol' UK then I can also recommend Ragworm (despite their 'Wormy the Geek' marketing misfire): I got a bunch of teeny-tiny boards made up to replace the security lock-out chips on PlayChoice-10 game boards and couldn't be happier with the service.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 23rd Feb 2017, 09:55   #4
LePhuronn
Multimodder
LePhuronn's Avatar
Thanks guys, I'll have a look.
Gareth: I was half expecting their weekly highlight to be called "RagWeek"
__________________
Reply
Tags
custom pcb, pcb
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
