Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 25th Feb 2017, 01:54   #1
hextechmods
What's a Dremel?
hextechmods has yet to learn the way of the Dremel
"Project Infinity" - Thermaltake Core P5 Mod
Hi Guys,
My name is Shane and I am a first time poster, new to the forum and wanted to start a work log on my upcoming build in Thermaltakes Core P5. Its around 3am here and I have been drawing up some draft sketches and non scale drawings on my graph pad to render some ideas for how this things will go together.
Concept: Create an infinity effect as the back plate of the Core P5, but not just the surrounds but accent each component with its own infinity effect.
The idea will be to place a new back plate over the existing case, add in the infinity effect using mirrored acrylic and component platforms to accenting each component. I haven't decided if I want to use MDF or Ply Wood or rather a combination of both. Follow this post to stay up to date!
System Specs;
Thermaltake Core P5
ASRock Fatal1ty Z270 K6 Gaming
Intel i7 6700K
EVGA Geforce GTX 970 FTW+ ACX2.0
Cougar GX800 PSU
Apacer 480GB M.2
Apacer 240GB SSD
16GB T.FORCE DARK DDR4 3000mhz
Custom Sleeved Cables
Fully Watercooled with Alphacool components.
You can see the photo of the effect below.
Follow us on Facebook to check out any new and upcoming builds.
* If you would like to jump on board with this build. It would definitely be appreciated. You can contact me below via email or facebook.
Thanks Everyone,
Shane Rayson
@: hextechmods@gmail.com (new domain coming soon)
W: www.facebook.com/hextechmods
hextechmods is offline   Reply With Quote
Old 25th Feb 2017, 08:58   #2
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Moved to Modding - Planning until there are pics of work in progress. Please report your post when you have posted some pics of work happening and I or one of the other moderators will move it back.
Thanks
GK
GeorgeK is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
