Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 2nd Mar 2017, 00:05   #1
silk186
Canadian
silk186's Avatar
silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.silk186 is definitely a rep cheat.
Issues with mechanical keyboard
I picked up a mini Keycool 87 from China in August 2015 and recently it is giving me trouble.
The 'M' key frequently does not register key strokes unless repeatedly pressed and when it does it can register between 1-3 key strokes. In addition the space bar frequently registers 2 key strokes. This is a big issue as I'm writing up my PhD thesis. I removed all the caps and cleaned it with water and a Q-tip and a can of air but it didn't fix the problem. It'd s pity because prior to these issues I was really enjoying the keyboard.
Does anyone have any suggestion for resolving the issue without replacing it?
__________________
i5 2500k @ 4.4GHz :: hyper 212+ :: GA-Z68-UD3H-B3 :: MSI 280x 3GB :: Corsair Vengance 2x4GB:: Samsung 830 256GB :: 2x Toshiba 3TB :: Corsair RM650 :: CM Storm Enforcer :: ASUS VE247H :: LG 42LB5500 :: Microlabs Fc360
silk186 is offline   Reply With Quote
Old 2nd Mar 2017, 00:36   #2
CrapBag
I Mod, Therefore I Own
CrapBag's Avatar
CrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming Saiyan
I bought a similar Chinese keyboard for my daughter, two in fact, but one has started randomly disconnecting and reconnecting.
Cheap boards don't last it seems although her other board from the same manufacturer isn't showing any problems yet (touch wood).
CrapBag is offline   Reply With Quote
Old 9th Mar 2017, 22:32   #3
silk186
Canadian
silk186's Avatar
Would replacing a few switches cheaply fix the problem?
__________________
Old 9th Mar 2017, 22:47   #4
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Replacing the affected switches might fix it, assuming it isn't a controller problem.
I assume the Keycool is a plate mounted board? That and the LEDs could make swapping out switches a wee bit more difficult. Break out the soldering iron.
Could also be dry solder joints on those keys - have a gander at the rear of the PCB and check out the soldering on them. Normally I'd say it was unlikely but, since everyone and their mother is making mech boards now, manufacturing standards have dropped.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|980 Ti|3007WFP-HC|Parvum S2.0
David is offline   Reply With Quote
Old 20th Mar 2017, 20:21   #5
hamza_tm
hamza_tm's Avatar
hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.
Does not smell of a switch problem, more likely a controller issue.
__________________
Whisper quiet gaming: 2500k@4.4Ghz | P67a-GD53 | Vengeance 8GB 1600Mhz | Force3 120GB | M4 256GB | WD15EARS 1.5TB (Icy Box USB 3.0) | BenQ XL2411T 144Hz | Asus Xonar Xense | Corsair 550D | GTX680
CM Storm Quickfire Rapid MX Brown (White Filco caps) | Zowie AM | Sennheiser PC360 | Razer Sphex
hamza_tm is offline   Reply With Quote
Old 20th Mar 2017, 21:36   #6
silk186
Canadian
silk186's Avatar
hmm, a switch would be easier to fix. That said, for some reason my 'm' started to work again yesterday. Even stranger is that now some keys are recording multiple key strokes with a single key press. I'm not sure if it is an improvement, I think it is less annoying.
__________________
Old 23rd Mar 2017, 15:38   #7
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
Keycool boards used to be alright, i have one somewhere at home, it was costar oem so it was fine.
if you're getting chatter then it's more often than not bad firmware, not a fault, just not very good firmware.
__________________
My Imgur
i7 6700k - 8GB - GTX 1070
keyboards.
Margo Baggins is offline   Reply With Quote
Old 21st Apr 2017, 15:04   #8
silk186
Canadian
silk186's Avatar
In case anyone is having a similar problem, this was suggested to me on Reddit.
Do any stores sell Isopropanol in the UK? I was surprised when I couldn't find it at boots or Tesco.
The software doesn't help my few keys intermittently not registering, though I've found if I press the space bar on the side it works more often. it does fix the most annoying problem to 2 characters forward and 3 characters back.
Buy isopropyl alcohol and a syringe. Fill it with a little bit of alcohol and get the needle in between the swift housing and the stem. Then squeeze a bit of alcohol in as many spots as you can reach and mash the key for a minute to get the alcohol to come out. Clean it up with a thick paper towel. I had two chattering keys and this totally fixed it for me.
You can read about the software here : http://forum.corsair.com/v3/showthread.php?t=157671
__________________
Old 21st Apr 2017, 15:22   #9
Margo Baggins
Moderator
you can buy it on amazon, I have a bottle of it at home.
__________________
My Imgur
keyboards.
Old 21st Apr 2017, 15:44   #10
Arboreal
I *am* a Dremel
Arboreal's Avatar
Arboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming Saiyan
Just bought some on the 'bay from Shiny Hardware. Although they are semi local to me, free postage was better than a drive out to somewhere that I don't want a morning out to go to
Arboreal is offline   Reply With Quote
Old 21st Apr 2017, 15:48   #11
silk186
Canadian
silk186's Avatar
I also found it on ebay. A decent price for 1L, but I really don't need that much and I'm not sure if it will even work. I was hoping for a smaller amount from a local shop, but it seems online is the cheapest and only real choice.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
