Go Back   bit-tech.net Forums > Partner Forums > I.C Diamond Compound Forum
Reply
Thread Tools
Old 13th Mar 2017, 02:25   #1
kimandsally
Minimodder
kimandsally has yet to learn the way of the Dremel
World number 1 on water. Using IC Diamond
Well guys I'm stoked up, been benching for a few years plodding along, then about 3 years ago I found IC Diamond this was giving me temps 3-8c better than anything on the market that equates to 50-100MHz in benchmarks.
If I were to add up all my benchmark scores and see what I've gained from using IC Diamond is around 150 points now that means from 3rd to 1st place.
I am a sporting person so I do let people know why I get such cooler reliable temps and quite a lot are now using it to great effect.
In my testing it beats the so called leader thermal grizzly consistently by 1c or slightly more.
I am now in 1st place as here:
http://hwbot.org/league/enthusiast?offset=-9
Big thanks to IC Diamond for making a superb product which I will continue to use not only for my benching but when I build PC's for people as, I build 1 off unique to the customer PC's.
kimandsally is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
