Reply
Thread Tools View Mode
Old 23rd Mar 2017, 10:47   #1
ciobanulx
Modder / Watercooler
ciobanulx's Avatar
ciobanulx has yet to learn the way of the Dremel
ctOS Tower 27 (modded Tt View 27) by SimpleModz
Hey guys,
Yet another case mod from my, I'm working on 3 at the moment.
This one is in the Thermaltake View 27 case. Iit will be Watch Dogs 2 themed and I'm calling it ctOS Tower 27.
I did an overview of the case a few months back. You can check it out below:
SPECS
Case - Thermaltake View 27
CPU - Intel Core i7 6700K
MB - ASUS Sabertooth Z170-S
RAM - 4 x 4GB Kingston HyperX Predator 3000MHz DDR4
GPU - NVIDIA GTX 1070 Founders Edition
SSD - 2 x 240GB Kingston HyperX Savage
HDD - Seagate TBC
PSU - Thermaltake Thermaltake DPS G RGB 650W
Custom cables & lighting - CableMod
Water Cooling - Thermaltake
I'll start this one as well with some photos of the case:
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
ciobanulx is offline   Reply With Quote
Old 2nd Apr 2017, 12:35   #2
ciobanulx
ciobanulx's Avatar
Hey guys,
Here's the first update
I made a cut out in the PSU shroud and added some acrylic cover panels. Next step is to add all the graphics.
The cut out will serve to illuminate through the bottom acrylic panel once the graphics are applied.
Cheers,
Alex
Old 6th Apr 2017, 13:41   #3
ciobanulx
ciobanulx's Avatar
Hey guys,
I have some pretty cool hard tube fittings to show you
The Thermaltake Pacific RGB fittings!
I did a video on these a while back and only getting around to using them now.
Cheers,
Alex
Old 9th Apr 2017, 02:21   #4
ciobanulx
ciobanulx's Avatar
Thermaltake Riing Plus RGB fans and Tt premium riser cable!
Stay tuned for more!
Cheers,
Alex
Old 14th Apr 2017, 14:44   #5
ciobanulx
ciobanulx's Avatar
Hey guys,
I have an update on the work I've done on the fans and SSDs. This will give you more of an idea for the theme and the vinyl that I'm using
Cheers,
Alex
Old 15th Apr 2017, 13:56   #6
ciobanulx
ciobanulx's Avatar
As the fans and SSDs, I added a similar skin to the ASUS Sabertooth Z170S motherboard
BEFORE
AFTER
And same with the pump/res combo
Stay tuned for more guys
Cheers,
Alex
Old 15th Apr 2017, 21:22   #7
kim
Multimodder
kim has yet to learn the way of the Dremel
very beautifull hardware, it looks promising
kim is offline   Reply With Quote
Old 16th Apr 2017, 01:21   #8
ciobanulx
ciobanulx's Avatar
Thank you
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
