Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 5th Apr 2017, 11:54   #1
mxdout
What's a Dremel?
mxdout's Avatar
mxdout has yet to learn the way of the Dremel
The Birthday Build
Hi again everyone!
So it was Roger's daughters 7th birthday and he wanted to make her something extra special! So... He got some mini components, and her favourite coloured dye, and built her a custom water cooled computer!
Take a look through some of the pictures from the build process!
Check out the video of our build!
https://youtu.be/PpAoO2dAWRo
PRODUCTS USED:
⭐️ #Noiseblocker - Fans
💸 http://amzn.to/2nqSLVf
⭐️ #BitsPower - Acrylic Tubing
💸 https://www.overclockers.co.uk/bitspo...
⭐️ #Monsoon - White EV2 Compression Fitting
💸 http://amzn.to/2naBPQL
⭐️ #MSI - Z270I GAMING PRO CARBON AC
💸 http://amzn.to/2nMsj9s
⭐️ #Mayhem - Pink UV Dye
💸 http://amzn.to/2nV3a9t
⭐️ #Mayhem - Ultra Pure H20
💸 http://amzn.to/2nMdyn8
⭐️ #Akasa - Magnetic LED strip lights
💸 http://amzn.to/2nMpB3K
⭐️ #Swiftech -Apogee XL2
💸 http://amzn.to/2mXxO1e
⭐️ #Kingston Predator 16GB DDR4 memory
💸 http://amzn.to/2nqSphg
⭐️ #Samsung PM 961 Polaris 128GB nvme
💸 http://amzn.to/2nqZdeP
⭐️ #Intel G4560 Kabylake Processor
💸 http://amzn.to/2nMsUbs
⭐️ #MSI GEFORCEŽ GTX 1050 TI 4GT LP
💸 http://amzn.to/2nMu3j2
⭐️ #Swiftech MCP35X Reservoir
💸 http://amzn.to/2mY0RkW
⭐️ #Swiftech MCRx40-QP "Quiet Power" Radiator Series
💸 http://amzn.to/2nMufig
⭐️ #Swiftech MCP35X2
💸 http://amzn.to/2nqXZ38
⭐️ #Fractal Design Define Mini C
💸 http://amzn.to/2nr7245
TOOLS USED:
🛠 Monsoon - Hardline Pro Mandrel Kit
💰 http://amzn.to/2mXFWih
🛠 Monsoon - Hardline Pro Cutting Kit
💰 http://amzn.to/2o89YQu
🛠 Dremel - Multi-Tool
💰 http://amzn.to/2nr73VX
🛠 Dremel - Cutting Disks
💰 http://amzn.to/2nMwxxZ
🛠 Dremel - Drill Bits
💰 http://amzn.to/2nr7dN3
🛠 Dremel - 100pcs Mixed Accessory Kit
💰 http://amzn.to/2naOdA8
🛠 Rolson - 28 pcs Offset Screwdriver Set
💰 http://amzn.to/2mXLWaG
🛠 Earlex - Heat Gun
💰 http://amzn.to/2nqUPwm
mxdout is offline   Reply With Quote
Old 5th Apr 2017, 22:14   #2
Behemoth
Timelord in training
Behemoth's Avatar
Behemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming Saiyan
Nice build ! Thats one lucky 7 year old too !
__________________
|AMD FX 6300 Black Edition|16 Gig of Ram|GTX 660|Corsair Carbide Air 240|
|MacBook Pro 7.1|Intel Core 2 Duo 2.4 GHz|6 Gig of RAM|
|Dell Latitude E6320|Intel Core i5 2520m 2.5 GHz|8 Gig of RAM|
Behemoth is offline   Reply With Quote
Old 6th Apr 2017, 15:54   #3
mxdout
What's a Dremel?
mxdout's Avatar
Thanks! Haha, she is a very lucky 7 year old! She loves it though, so I think we nailed it!
Reply
Tags
computer build, custom water cooled pc, pc build, water cooling
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
