Hey everybody, I'm working on a lighting system for my underwater camera rig and I need a very oddly shaped PCB made. Basically the way this is supposed to work is that I will solder two rows of large LEDs onto it (like these) with the center trace being one polarity and the two outer traces being the other. A cable from each trace will go up and be connected to a battery on the surface. The hole in the center goes on a 5/8-11 bolt and then the whole mess goes into a can. To prevent shorting underwater, once it's solvered up I plan to cast the whole thing in epoxy resin. This video shows the rig it's intended to go on: I know I could get the kit online and etch one, but I'm hoping someone on here has the stuff lying around and might be able to make this for me for a small cost.
Apologies for the thread jack, but how much would you charge Boscoe? I'm toying with the idea of a small circuit board to split SATA power around a few places and it'd look fancier than some veroboard.
