Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 15th Feb 2004, 09:38   #181
rool
Minimodder
rool has yet to learn the way of the Dremel
I must say thanks, these models are great. Made many drawings using them.
I'm missing a model of an Epia board though. Has anoyne made one?
rool is offline   Reply With Quote
Old 15th Feb 2004, 13:16   #182
Pug
What's a Heatsink?
Pug's Avatar
Pug has yet to learn the way of the Dremel
Awesome contribution Jazzle.
I'd been put off using Sketchup till now but I reckon you just smoothed out a massive chunk of the learning curve needed with this thread.
Props man.
__________________
For my next miracle, I'm going to turn water into... FUNK!
WizD Forums
Wizard Designs
Cooling with a touch of class
Pug is offline   Reply With Quote
Old 15th Feb 2004, 17:00   #183
jezmck
I Mod, Therefore I Own
jezmck's Avatar
jezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyan
Thanks, but I also have to thank everyone who contributed models/advice/tutorials to the thread - it wouldn't be worth it without their contribution.
And I should also thank *sniff* my girlfriend for putting up with me, and...
__________________
Have you seen The SketchUp Components Collection's latest items?
jezmck is offline   Reply With Quote
Old 21st Feb 2004, 01:41   #184
hypocrisy86
Banned
hypocrisy86's Avatar
hypocrisy86 has yet to learn the way of the Dremel
those links still wont work.....
hypocrisy86 is offline   Reply With Quote
Old 21st Feb 2004, 14:47   #185
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin has yet to learn the way of the Dremel
Stupid Host... give me a few days to get another.
Tulatin is offline   Reply With Quote
Old 21st Feb 2004, 15:45   #186
Frink
What's a Dremel?
Frink has yet to learn the way of the Dremel
:Edit: Fixed my issue. And thanks for the components in this thread, very handy.
Frink is offline   Reply With Quote
Old 21st Feb 2004, 18:12   #187
hypocrisy86
Banned
Ok
Old 25th Feb 2004, 18:13   #188
mcbeckel
Multimodder
mcbeckel has yet to learn the way of the Dremel
Coolermaster Musketeer...If anyone has any great pics of the needles and markings inside the windows, I can add that.
SketchUp File
mcbeckel is offline   Reply With Quote
Old 25th Feb 2004, 21:22   #189
jezmck
jezmck's Avatar
please don't add any dials - these models should just be sketches - as it is your model is perfect
__________________
Old 25th Feb 2004, 21:26   #190
Tulatin
The Froggy Poster
Tulatin's Avatar
it should be noted that the drive is about .6 inches too wide, as is the cd-rom it's modelled on. Sorry to kill your party chap.
Old 25th Feb 2004, 21:28   #191
ouija
Trust me, I am doctor!
ouija's Avatar
ouija has yet to learn the way of the Dremel
The width of the model is 100% accurate.
CD-ROM bays are not 5 1/4" wide
ouija is offline   Reply With Quote
Old 25th Feb 2004, 21:30   #192
Tulatin
The Froggy Poster
Tulatin's Avatar
in-bloody deed.... it would have been nice if they called them 5 3/4 inch bays....
Old 25th Feb 2004, 21:33   #193
ouija
ouija's Avatar
5 1/4" floppy discs were 5 1/4" wide
Old 25th Feb 2004, 21:34   #194
Tulatin
The Froggy Poster
Tulatin's Avatar
well that would explain it... well, this just goes and buggers my case designs....
Old 25th Feb 2004, 21:35   #195
ouija
ouija's Avatar
If the design is to scale, you can resize the entire model to a specific dimension and replace the incorrect line with one that is 5 13/16" wide
Old 25th Feb 2004, 21:37   #196
Tulatin
The Froggy Poster
Tulatin's Avatar
Not that Easy Ouija. These cases have inch thick cut bezels, and drive cages. Btw - what's the accurate dimensions on 3 1/2 drives?
Old 25th Feb 2004, 21:41   #197
ouija
ouija's Avatar
4"
Old 25th Feb 2004, 21:42   #198
Tulatin
The Froggy Poster
Tulatin's Avatar
Ah bugger. There goes the case. 5.75*1.5, 4*1
Old 26th Feb 2004, 02:52   #199
philb
Multimodder
philb's Avatar
philb has yet to learn the way of the Dremel
very noob question on sketchup
just downloaded it but thetutorilas are ****.
get how most of it works nut how do you round edges like on the edge of if it not a straight 90 degrre join? Chamfered like the edge of table?
and are all your drwaings to scale?
last one how do you make thing protrude at a certain angle?
philb is offline   Reply With Quote
Old 26th Feb 2004, 08:02   #200
ouija
ouija's Avatar
The video tutorials are superb for beginners.
Use the measure tool and draw an arc on the corner you want to round.
There is also a protrator tool.
All my models are to scale, can't say the same for everyone though.
Reply
Tags
components, scc, sketchup
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
