Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 5th Feb 2015, 04:11   #3141
jodah175
Wannabe Modder
jodah175's Avatar
jodah175 is the Cheesecake. Relix smiles down upon them.jodah175 is the Cheesecake. Relix smiles down upon them.jodah175 is the Cheesecake. Relix smiles down upon them.jodah175 is the Cheesecake. Relix smiles down upon them.jodah175 is the Cheesecake. Relix smiles down upon them.jodah175 is the Cheesecake. Relix smiles down upon them.jodah175 is the Cheesecake. Relix smiles down upon them.jodah175 is the Cheesecake. Relix smiles down upon them.jodah175 is the Cheesecake. Relix smiles down upon them.jodah175 is the Cheesecake. Relix smiles down upon them.jodah175 is the Cheesecake. Relix smiles down upon them.
Tubing is very easy to do in sketchup. jsut draw out your centerline, and use the "follow me" tool after highlighting the paths you want the tubing to follow. :-)
__________________
AMD FX4100 Zambezi, ASUS M5A97LE R2.0, 8gb Corsair Vengeance DDR3 1600, XFX R9 270X DD, Corsair CX750M, Samsung 850 EVO 250Gb, WD 2Tb Green. case = sitting on mobo box. :-P
jodah175 is offline   Reply With Quote
Old 26th Feb 2016, 15:38   #3142
IWantAnA2
What's a Dremel?
IWantAnA2 has yet to learn the way of the Dremel
Wow. This is awesome. If only I'd seen this before I tore my PC apart and laid it out. :/
IWantAnA2 is offline   Reply With Quote
Old 8th Feb 2017, 19:05   #3143
alan1476
What's a Dremel?
alan1476 has yet to learn the way of the Dremel
Excellent, love the build. Would like to see it already built , love the cooler in the bottom
alan1476 is offline   Reply With Quote
Reply
Tags
components, scc, sketchup
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
