Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 18th Dec 2003, 18:49   #61
ouija
Trust me, I am doctor!
ouija's Avatar
ouija has yet to learn the way of the Dremel
Not too long
ouija is offline   Reply With Quote
Old 18th Dec 2003, 19:11   #62
Sc0rian
Here comes the farmer
Sc0rian's Avatar
Sc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run CrysisSc0rian can run Crysis
day then...
__________________
\o/
Sc0rian is offline   Reply With Quote
Old 18th Dec 2003, 19:20   #63
jezmck
I Mod, Therefore I Own
jezmck's Avatar
jezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyan
ouija - you should make a web page of all your components, you have made some great pieces and they should be put together.
we could collaborate if you like (though it may be after my exams in Jan)
__________________
Have you seen The SketchUp Components Collection's latest items?
jezmck is offline   Reply With Quote
Old 18th Dec 2003, 19:21   #64
ouija
ouija's Avatar
I was considering making a page of them. I would also make some better quality exports of them since the JPG compression is too high by default.
Old 18th Dec 2003, 19:30   #65
jezmck
jezmck's Avatar
__________________
Old 18th Dec 2003, 19:52   #66
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin has yet to learn the way of the Dremel
Just finished a bayres, and soon clear/uv fans (modded from pheaton's), and a nice modded case with VFD integrated.
Tulatin is offline   Reply With Quote
Old 18th Dec 2003, 22:21   #67
El Nosba
Multimodder
El Nosba's Avatar
El Nosba has yet to learn the way of the Dremel
Abit IC7 Max3
*Double Edit *
seems my host doesnt like direct linking... o well
just click my sig, and the rest should be self explanitory
( or if your lazy like me... just click motherboards/intel and there it is )
weeeeee all done, wasnt too bad... the most annoying part of the whole thing was the northbridge believe it or not , and as always the 3 pin male connector on the board stays and everything else with the northbridge goes once you delete it
btw, nice duron ouija
musta went insane doing all the pins
El Nosba is offline   Reply With Quote
Old 18th Dec 2003, 22:41   #68
ouija
ouija's Avatar
The pins were easy once I worked out the spacing.
Old 18th Dec 2003, 23:39   #69
ishiii
Minimodder
ishiii has yet to learn the way of the Dremel
El Nosba, thats some sweet work on the abit mobo. Thanks dude
Tulatin, I would love to see that bay res.
Jazzle and ouija, and everyone really, I think it would be sweet if there was one page with all the components on it. El Nosba has some sweet stuff on his page, Jazzle has some great stuff to, and ouija has dome some great work (I aspire to such greatness). I would love to see it all come together on one page.
Keep up the great work guys
ishiii is offline   Reply With Quote
Old 18th Dec 2003, 23:44   #70
ouija
ouija's Avatar
I reckon a site with a database with all the items, subcategorised, and an admin section for adding/removing/editing models would be the business
Old 18th Dec 2003, 23:47   #71
Tulatin
The Froggy Poster
Tulatin's Avatar
Links Broke. Modells Removes. Hopefully post will get deleted.
Old 19th Dec 2003, 00:10   #72
El Nosba
Multimodder
El Nosba's Avatar
to be honest, i woulda did that with my site... but there is a limit to wat html i could look up and apply without getting lost
its so sloppy
np, it ate most of which woulda been a most boring day, happy to do it
Old 19th Dec 2003, 00:58   #73
death_star
Supermodder
death_star's Avatar
death_star has yet to learn the way of the Dremel
If anyone cares, I made a A-Open (I think) Case for my mom. Here ya go.
http://www.ihateaol.co.uk/misc/pics/...8AOpenCase.skb
I get on it.
death_star is offline   Reply With Quote
Old 19th Dec 2003, 00:59   #74
Tulatin
The Froggy Poster
Tulatin's Avatar
Nice! and 100% accurate size too! (even nicer). I suppose i'll set to work seeing what i can cram in there
Old 19th Dec 2003, 01:24   #75
death_star
Supermodder
death_star's Avatar
Got that Sketch-up collection thing in php and mysql working. Only up when my computer is up.
http://205.206.184.212/sketch-up/index.php
Ill host on a diffrent server later. Untill then live with it. Go add all your models
Old 19th Dec 2003, 01:25   #76
Tulatin
The Froggy Poster
Tulatin's Avatar
Keep up the great work guys, and i'll keep up modding and assembling.
Old 19th Dec 2003, 02:47   #77
El Nosba
Multimodder
El Nosba's Avatar
Originally posted by Tulatin
Next Release... A slightly colour corrected Max3 (the purple was supposed to be a light blue, but excellent job on the board!), with a 9600pro attached (thanks to El Nosba for both of these sweet peices of work), with three swifty blocks strapped on, and the card is sink'd. If you're planning to WC an intel pc with swifty parts, and gonna use sketchup - this is the model to use.
sorry about that... im color blind.... geuss the secrets out ehh ?
*edit* the placement of the 9600 is a little to the right in the agp slot, with my cards/memory/ect... there made to fit snug right in the hole the way it should ( with the exception of the sound card, which its pci slot is placed a little off [ thats wat you get wen u dont compare cards with the master design you have], and ive yet to fix because of being busy with school and stuff )
just somethin i noticed
Old 19th Dec 2003, 02:56   #78
Tulatin
The Froggy Poster
Tulatin's Avatar
Hey dude - no worries. I didn't know about build lines till ouija told me - made work on this Aopen case MUCH easier (currently, 120mm rear exhaust, perfectly fited top window, 80 mm side intake, 80mm roof blow - all done with constuctions lines for perfect alignment. Plus, i don't mind modding and fixing - i love this stuff.
Old 19th Dec 2003, 16:09   #79
ishiii
Minimodder
Hi guys
Any ideas on how to make tubing in sketchup? I havent watched everysingle tutorial they have online, so I was wondering if anyone has taken a shot at it, or what tools one would use to make some tubing.
I can easily make a 1/2inch ID circle and push pull on it, but how can I bend it, and curve it, and still keep the shape?
Ideas comments, suggestions, they are all welcome
ishiii
Old 19th Dec 2003, 17:41   #80
Tulatin
The Froggy Poster
Tulatin's Avatar
That i still wonder myself - once i know, the single and dual 120 rads will be done . As to the Aopen - she's almost done.
Reply
Tags
components, scc, sketchup
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
