Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 23rd Jan 2004, 21:49   #141
IaKoVl
Multimodder
IaKoVl has yet to learn the way of the Dremel
!!! Noob Alert !!!
So i'm a noob
remmember , you were once a noob 2
IaKoVl is offline   Reply With Quote
Old 23rd Jan 2004, 22:12   #142
jezmck
I Mod, Therefore I Own
jezmck's Avatar
jezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyanjezmck is a Super Spamming Saiyan
just kidding - sketchup details are detailed further up the thread, but just look at http://www.sketchup.com for more info
__________________
Have you seen The SketchUp Components Collection's latest items?
jezmck is offline   Reply With Quote
Old 25th Jan 2004, 03:43   #143
comprocket
Modder
comprocket has yet to learn the way of the Dremel
I am going crazy with a casefan...can someone post one you have completed? I know I have seen them around here, but cant find the model...
also, am I a complete noob if i cannot seem to get curves to work right???
Once done, i wil post a pic of my custom acrylic case!
comprocket is offline   Reply With Quote
Old 25th Jan 2004, 05:37   #144
comprocket
Modder
Single Sided DDR Ram
Click here to download
Double Sided DDR Ram
Female Molex Connector
Sony Clie SJ-22
As far as I can tell I made these almost perfectly to scale....but if I am wrong please tell me and I will correct it. Also if you wanna touch mine up, just do it, and send me the files so i can update mine here...
Old 25th Jan 2004, 06:16   #145
Morphine
weeee!
Morphine's Avatar
Morphine has yet to learn the way of the Dremel
go to nosba's site and see his misc. files
__________________
Back from the dead.
Found a bigger money pit than PCs. My Tibby!
Morphine is offline   Reply With Quote
Old 25th Jan 2004, 12:01   #146
ouija
Trust me, I am doctor!
ouija's Avatar
ouija has yet to learn the way of the Dremel
Curves for fanblades aren't coplanar so you will need to manually build the surface up and then soften the edges.
ouija is offline   Reply With Quote
Old 26th Jan 2004, 14:34   #147
comprocket
Modder
nosba, could you add my pieces to the site?
Old 4th Feb 2004, 10:32   #148
Arien
Ultramodder
Arien has yet to learn the way of the Dremel
Sony Clie SJ-22
Nice models but your molex connector is way too wide.. or short.. have a look at the dimensions .
Arien is offline   Reply With Quote
Old 5th Feb 2004, 16:05   #149
Azazel100
What's a Dremel?
Azazel100 has yet to learn the way of the Dremel
I've been wondering why you guys prefer sketchup to some bigger tool, like 3dsmax- they've got better/more editing tools ?? ( and why models exported to 3ds have wrong dimensions...)
Azazel100 is offline   Reply With Quote
Old 5th Feb 2004, 16:12   #150
ouija
ouija's Avatar
Sketchup is so quick and easy to learn. It's versatile in that you can sketch with as much or as little detail as you want and make changes so quickly and easily.
Exported models with incorrect dimensions have been drawn using the wrong units.
Old 5th Feb 2004, 16:26   #151
jezmck
jezmck's Avatar
what he ^^ said.
I use Sketchup cos I want to sketch. If I want to take ages making somthing that looks realistic, I'll plan it in Sketchup and make it in the real world and take photos!
__________________
Old 6th Feb 2004, 02:55   #152
Azazel100
What's a Dremel?
Heve you tried using max(it's what I'm using)??
I did not see any boolean operation, lofts,beizer curves, and these seem to me like basic modeling stuff... but maby they are there, just could't find them
Old 6th Feb 2004, 03:33   #153
comprocket
Modder
The reason I use Sketchup is that I cannot understand how to do everything in 3DMax....I was able to get the trial of sketchup, and get modding on my first try. No need to know formulas, and complicated ways to bend lines, and ways to complete cubes!
Old 6th Feb 2004, 08:10   #154
ouija
ouija's Avatar
Sketchup is for sketches.
Old 6th Feb 2004, 18:42   #155
jezmck
jezmck's Avatar
what he ^^^ said.
and we've both said it before...
__________________
Old 6th Feb 2004, 19:18   #156
Azazel100
What's a Dremel?
Simplicity above all...
Ok be me
Old 6th Feb 2004, 19:21   #157
ouija
ouija's Avatar
<rolf>Can you tell what it is yet?</rolf>
Old 6th Feb 2004, 21:13   #158
Langer
Jesse Lang
Langer's Avatar
Langer has yet to learn the way of the DremelLanger has yet to learn the way of the Dremel
Gameboy advanced SP?
__________________
project:HELIOS -- project:PROMETHEUSCU
Langer is offline   Reply With Quote
Old 6th Feb 2004, 21:16   #159
ouija
ouija's Avatar
Old 7th Feb 2004, 07:27   #160
hypocrisy86
Banned
hypocrisy86's Avatar
hypocrisy86 has yet to learn the way of the Dremel
My computer cant play/read SKP files
can i download a program for this?..
a link would suffice...
hypocrisy86 is offline   Reply With Quote
Reply
Tags
components, scc, sketchup
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
