Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 26th Nov 2010, 01:24   #41
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
Great guide!
Speaking of Mcmaster, I bought this Drill bit set for Plastic from them
http://www.mcmaster.com/#drill-bits-...astics/=9hldrb
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 14th Dec 2010, 02:05   #42
Djayness
phwupupupup
Djayness is definitely a rep cheat.Djayness is definitely a rep cheat.Djayness is definitely a rep cheat.Djayness is definitely a rep cheat.Djayness is definitely a rep cheat.Djayness is definitely a rep cheat.Djayness is definitely a rep cheat.Djayness is definitely a rep cheat.Djayness is definitely a rep cheat.Djayness is definitely a rep cheat.Djayness is definitely a rep cheat.
This information relates to those using a CNC.
Machine: 10,000rpm
Single Pass: 3mm
Tool: Straight cutter, 30 degree rake
Speed: 4000mm/min
Direction of Cut: Climb
All these factors combined = incredible finish on acrylic cuts.
Djayness is offline   Reply With Quote
Old 13th Mar 2011, 14:41   #43
FDAD
What's a Dremel?
FDAD has yet to learn the way of the Dremel
Excellent guide and description of the various types of plastics!
FDAD is offline   Reply With Quote
Old 15th Apr 2011, 10:55   #44
Genghis
Minimodder
Genghis's Avatar
Genghis has yet to learn the way of the Dremel
great guide... thank you a lot for this informations
it is possible to do chamfer hand made on plexiglas.
i saw a video where a man chamfer edges with a plate tool with triangular edge cut
this is the tool
the question is : in a hole, how can i do my chamfers?
Genghis is offline   Reply With Quote
Old 15th Apr 2011, 13:19   #45
Javerh
Topiary Golem
Javerh's Avatar
Javerh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the Dremel
Machine: 10,000rpm
Single Pass: 3mm
Speed: 4000mm/min
You might want to call the speed as feed instead. Usually speed relates to tool diameter and spindle rpm. So for your case someone could argue that for that speed and that rpm, you are using 0.8mm diameter end mill. Actually, what tool are you using?
__________________
Project: Seawolf
Project: 1
Project: Flux (est 2012)
Modders make project logs. Project logs make mods. Mods make modders.
Javerh is offline   Reply With Quote
Old 25th Aug 2011, 13:54   #46
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Thanks for the guide - have some rep
__________________
Best regards, Nutman
Projects: Nutman - Hampen - F.O.B. T.C. - BabyShark - The Scratchbench
Nutman is offline   Reply With Quote
Old 2nd Oct 2011, 05:00   #47
NewToPc
What's a Dremel?
NewToPc has yet to learn the way of the Dremel
nice info bro! thank you for sharing!
NewToPc is offline   Reply With Quote
Old 5th Oct 2011, 09:11   #48
joolz1
Minimodder
joolz1 has yet to learn the way of the Dremel
Yer thx ,)
joolz1 is offline   Reply With Quote
Old 8th Apr 2012, 22:52   #49
Foregasm
Multimodder
Foregasm's Avatar
Foregasm has yet to learn the way of the Dremel
What about the 'unibit' drill bits? are they any good for plastics?
Foregasm is offline   Reply With Quote
Old 27th Apr 2012, 09:27   #50
kelvinb
BF3 Username - D0rmarth
kelvinb is definitely a rep cheat.kelvinb is definitely a rep cheat.kelvinb is definitely a rep cheat.kelvinb is definitely a rep cheat.kelvinb is definitely a rep cheat.kelvinb is definitely a rep cheat.kelvinb is definitely a rep cheat.kelvinb is definitely a rep cheat.kelvinb is definitely a rep cheat.kelvinb is definitely a rep cheat.kelvinb is definitely a rep cheat.
Just a quick question what tool do I use to make threads for my screws, what would you say is that standard size I would need for a PC case
__________________
kelvinb is offline   Reply With Quote
Old 27th Apr 2012, 13:52   #51
bluc
Supermodder
bluc has yet to learn the way of the Dremel
Any ideas on embedding leds for edge lighting. Acrylic is fairly thin and am wondering how to drill a hole into the edge to hot glue in an led? Perhaps a miniature doweling jig? Also those drill bits pictured are they avaialable in metric any ideas where to get a set in australia?Great guides Thanks in advance.
edit: Another quick question if you have a bent piece of acrylic and you edge light it does the light travel around the bends like in optic fibre? I read somewhere it is fibrous and have been wondering about edge lighting around bends.
bluc is offline   Reply With Quote
Old 26th Jun 2012, 04:38   #52
bluc
Supermodder
I have seen video of people welding the acrylic with acetone is this bond as strong as the one created by weld on cement?
EDIT: I joined to scrap bits with the acetone the joint is self supporting after about 10 mins I will let it sit for 24 hours then I will torture it to see how strong it is and report back cheers.
Edit 2 acetone= epic fail. Not at all a strong and on inspection of the acrylic it barely marks the acrylic. Can cross that off the list! Weld-on on order:-)
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
Old 14th Jul 2012, 10:23   #53
bluc
Supermodder
When using weld on #3 how smooth should the edge be to get a strong bond i finished the parts with 180 grit sandpaper on a disc sander they are pretty smooth but a few very shallow grit marks in the edge. Its a reservoir mount and will support about 1.5 kg is this finish ok?
__________________
Old 16th Aug 2012, 11:57   #54
Wissel
Minimodder
Wissel has yet to learn the way of the Dremel
Really good guide and exactly what I needed.
I downloaded Alibre Xpress as recommended in the OP and its great but wondered if there's better software (free or v.cheap) that people would recommend?
Wissel is offline   Reply With Quote
Old 19th May 2016, 13:22   #55
Bitwacker
C# forever
Bitwacker's Avatar
Bitwacker has yet to learn the way of the Dremel
A great guide. The posting seems a little old, does this still reflect the current practices? Who are the current players in the marketplace?
__________________
i7-3930K@3.4Ghz | 64GB@1600 | 2x120GB SSD (RAID 0) | 2x1TB Samsung F1 | 30" DELL | 2x23" Dell | Cooling: single water cooling loop
Bitwacker is offline   Reply With Quote
Old 26th May 2016, 13:08   #56
Mully
What's a Dremel?
Mully has yet to learn the way of the Dremel
Machining and joining polycarbonate rod
Hello,
I am not sure if I should tack my topic on to this thread, or start a new one. I would appreciate guidance. Honestly, I could not find the procedure for starting a new one.
I want to machine the ends of polycarbonate rods and adhere them to other polycarbonate rods in a T - joint. I hope to cut a "saddle" into the ends of 1/2" rods with a 5/8" bit and join them to un-manipulated 5/8" rods. I thought I'd use a solvent cement so i'm looking for a fairly smooth cut and final joint. However I will be painting (gloss finish) the end result so I suppose there is some room for error as long as I can "touch up" before painting.I hope to mount my handheld router on my router table and build a very substantial jig to feed the workpiece into the cutter. I gather from some prelim research that I'm dealing with a soft plastic and should use an "O" flute tool. Can anyone offer advice on the specific bit (steel/carbide, straight/spiral, single/double) (I even read about using two bits, one to start and one to finish), the adhesive, touch up options, and paint type.
The finished piece is basically a grid- shaped art project and will hang on a wall. There will be a few blocks of plastic here and there within the grid. The piece will need to support only its own weight.
Any advice or direction appreciated.
Thanks,
Rob
Mully is offline   Reply With Quote
Old 10th Sep 2016, 19:00   #57
Zanib
Minimodder
Zanib's Avatar
Zanib has yet to learn the way of the Dremel
Just my 2 cents... when I machine plastics I use a single or twin flute bit at a higher feed rate with more shallow passes as it then conducts the heat away from the work piece in the chips giving you a crisp edge
__________________
i7 4790k @4.2, Asus Z-97, 16GB Vengance DDR3, x2 GTX670, 256 M4 SSD, 512GB EVO, Thermaltake 1200W, Dell U2711 monitor, Dell 3007WFPHC , Asus 23"
Zanib is offline   Reply With Quote
Reply
Tags
guide
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
