gtx660 performance issues
Discussion in 'bit-tech Folding Team' started by ross2011, 13 Jan 2014.
  1. ross2011
    ross2011 folding for my daughter
    11 Nov 2011
    Hi every body, I have two gtx660 in my rig and they are working on the same project(1 each) but getting very different ppd, they are working on core 17 project 8900
    gpu 0 will take 4,72 days as gpu 1 will be finished in 20 hours, my rig is as signature, sli is disabled, cpu is working on 4 cores, my 2600k has 4core 8 threads, I am using 332.21 drivers
    any advice is very welcome
    Ross
  2. johnim40
    johnim40 Minimodder
    23 Apr 2009
    hi to get better points drop back to 327.80 drivers as any newer cut the points in half also there has been problems with the servers and a lack of core 17
  3. ross2011
    11 Nov 2011
    I have put back to 327.23, hopefully they will both increase but bring in similar results not one take 3 days as long to complete a project
    ross
  4. johnim40
    johnim40 Minimodder
    23 Apr 2009
    ok thats ok im getting 48k ppd with my 660s also with sli enabled as it does not matter these days with sli enabled
    each gpu will need a core whether a ht core or normal core so make sure 2 are free for the gpus
  5. ross2011
    11 Nov 2011
    yeah I have set my cpu to 6 cores, also both cards are producing about 43000/45000 now, where before one was 18000 and the other was 1400, cheers for the help, making 98000 ppd now
  6. johnim40
    johnim40 Minimodder
    23 Apr 2009
    no worries have fun
