hi guys wondering if you can help lookin to upgrade my 460 1gb gpu currently folding on it 24/7 an I have it watercooled I wanna upgrade it but don't know what to.... I can either keep my 460 for folding...an using the new gpu for games.. or have a new gpu for both..... thing is money is an issue.... lookin on marketplace an ebay..... how good are quadros for folding? what amd gpu would I need to be the same or better than my 460? what amd is good at folding? thanks for any help
hi i get ppd 460 10-16k 336 cores 560ti 20-25k 384 cores 660 45-50k 960 cores 660ti 60-75k 1344 cores 760 60-70k 1152 cores i have not used amd though
hi the 650 has 384 cores the more the better the 650ti has 768 cores i have not had 1 but no idea what it gives i just found this but dont know how correct it is http://compdewddevelopment.com/proj...&showOnlyAssignedProjects=true&sortByPpd=true
If you can stretch, the 7970 from AMD is pushing 100-120k PPD right now on beta units. Can get for about £220. Can't guarantee how long beta units will last though.
