Scratch Build – In Progress Project SR2 (800D+TJ11+Ascension)
Discussion in 'Project Logs' started by douglatins, 10 Jun 2010.
  1. douglatins
    douglatins What's a Dremel?
    28 Nov 2009
    I want to make a case future proof and totally awesome, since I live in South America, cases are expensive due to shipping and taxes, for example a MMods Ascension case would set me back on 2K moneys
    First stages: Design and Modeling
    In this first stage I'll ask for help on improving the design and features of the case. You cant see the motherboard tray due to that I'm buying. It will be placed on top, RAVEN style. I can pretty much go crazy on the lines since this will be CNC milled
    Right I'm looking to build a CNC machine. :jawdrop: so expensive :waah:
    Latest 3D render:
    700x730x450mm
    I need some designs to put in it to look "awesomer"
  2. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    Is that... FOUR QUAD RADIATORS?!
    or is that... TWO TRIPLE RADIATORS?!
    or is that.... FOUR QUAD RADIATORS AND TWO TRIPLE RADIATORS?!
    You want to throw a Mora on those 9 120mm fans you have at the rear too?
    I don't think you will be cooling limited.
    I commend this insanity to the house.
  3. douglatins
    28 Nov 2009
    Hehe, the radiator brackets i made are compatible with either a quad 120/140 and triple 120/140
    Max radiator support is 4 Quad 140mm rad 2 Triple 140mm rad.
    If i can get sponsored by hardwarelabs I will aim to fill it, if come from my pocket I will start with one Quad only.
    The Mora... uhm i didn't think of that... thanks
  4. shah
    shah Minimodder
    29 Jan 2010
    totally future proof, you could easily run/cool an engine in there :D. This thing would be massive. What are the dimensions.
  5. douglatins
    28 Nov 2009
    730x700x450mm (HxLxW)
  6. shah
    shah Minimodder
    29 Jan 2010
    now that was there with the picture and could not see it :duh:
    Have you thought about the colour scheme and the outside look. By looking at all those fans would this thing be even quiet. :worried:
  7. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Why do you need all those radiators ?!?!? :worried:
  8. DeadP1xels
    30 Nov 2009
    Looks extreme
    Me like!
    1 thing so the ports will be facing up? how are you going to make that look clean
    this is going to look cool
  9. Remmes
    Remmes Be One With Your Mod
    24 May 2010
    make the ports face down :D never seen that before, lots of fanholes O_O
  10. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    That case seem made for massive lot of cooling. I guess there will be some OC, won't there?
  11. douglatins
    28 Nov 2009
    Added a grill top to render, mice and keyboard will be routed inside the case. All except monitor, since I don't have a cable that massive
    Actually that depends on how much money i will have left to buy WC stuff. But a case is the beginning
  12. douglatins
    28 Nov 2009
    New designs on schools PC
  13. douglatins
    28 Nov 2009
    Latest render
  14. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    The definition of extreme !!!! Moaaaaaaaaaaaar pls! ;)
  15. bagman
    bagman Minimodder
    18 Apr 2009
    that is crazy can't wait till this project gets going
  16. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I love it, its so mental and off the wall :D I don't understand where the motherboard fits exactly though... You do realise this case is nearly as wide as my case is long...
    Maybe some wheels are needed...
  17. douglatins
    28 Nov 2009
    The motherboard is going like the raven, i didnt make the hole top since i need the SR2 tray dimensions for it
    Thanks guys.
    Ordered the tray over here: https://www.evga.com/forums/tm.aspx?m=423533
    Big thanks to ajr23
  18. douglatins
    28 Nov 2009
    :thumb:
  19. AnG3L
    19 Mar 2009
    Thats the spirit dawg! ;)
  20. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Good job:thumb:
    But many fans or holes for radiators , that wont be a quiet build..
