News Lian Li launches wall-mountable O-Series cases
Discussion in 'Article Discussion' started by Gareth Halfacree, 18 Dec 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Looks nice! Would you do a review on those cases pretty please?
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    They look nice, but nearly 20L for an 'ITX' case? That's enormous! Particularly as it doesn't look like you could fit a full length GPU even with the drive cage removed (max length 190mm).
  4. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Is it just me, or does the idea of wall mounting a case for "display" purposes not seem a bit flawed? Sure, it'll look nice if you don't plug anything into it, but as soon as you've connected up power, display, speakers, etc it'll look like the proverbial dog's dinner. Too many wires :D
  5. Aterius Gmork
    25 Sep 2007
    Judging from the picture the IO-shield will not be at the back of the case but hidden behind a panel. presumably routed out of the right side. You can route the cables behind the wall or under your desk to hide them. But yeah, opportunities for cable management will make or break the case.
  6. Xir
    Xir Modder
    26 Apr 2006
    A Decade or so ago, there was talk that a VGA Riser Card would hamper the bus stability between the chipset and the graphicscard.
    Now we don't really have a chipset anymore, but still, would a riser like this have an influence on CGU-GPU communications? (as it should influence signal transit time and add a second contact resistance)
  7. keir
    keir S p i t F i r e
    5 Oct 2003
    ooh that looks nice.
  8. Nexxo
    23 Oct 2001
    That... actually looks not bad at all...
  9. theshadow2001
    3 May 2012
    a bit of trunking would tidy it up nicely
