PSU Audio Jacks as Modular Connectors
Discussion in 'Hardware' started by TheAbyssDragon, 13 Sep 2009.
  1. TheAbyssDragon
    TheAbyssDragon Gafgarion
    8 Dec 2005
    I'm adapting a 180W 1U power supply to be a DC backbone for a couple components, including a PicoPSU.
    What I would like to do is remove all the psu's wires and insert 3 or 4 female 1/4" (3.5mm) audio jacks (ala Orac3). Then create a couple of custom cables which have a male audio jack on one end, and the necessary DC plug on the other.
    Before I get into the nitty gritty, I'd like to hear opinions on two matters:
    • First, I can't decide if I want to use TRS (3 contact) or TRRS (4 contact) connectors; in other words, I'm not sure if I want to maintain the two ground wires typically present in a power supply, or combine them into one.
    • Second, what order should I place each wire on the connector? This may be irrelevant, since hot swapping will be impossible; due to the nature of audio jacks, you can't insert or remove one without shorting adjacent contacts.
    Thanks for any input!
  2. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    bad idea. if you inevitably pull one of the connectors out while the psu is on (will happen, believe me), it will short out, and then shut down, if you're lucky. I'd suggest going with XLR plugs instead.
    If you insist on TRS or TRRS though, go with the TRS. It doesnt' really matter what order they go in, as long as they are all the same orientation. In audio though, the ground is the sleeve, which corresponds to the largest part on the back. go ahead and combine them.
  3. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    I second the bad idea vote. I'm using for my modular PSU design 4-pin DIN connectors, the older brother of the XLR design. The only thing I'm using audio connectors for is the 3.3v line for the fifth wire on the SATA plugs. So the audio plugs will only carry 1 voltage and no ground.
  4. TheAbyssDragon
    8 Dec 2005
    I'm not too worried about accidentally removing them, since the psu will be inside a case. However, I will look into alternative options.
    I received my power supply from Newegg and after removing the shell, I realize how little room I have. I think I'll be forced to move the modular system external to the supply, either inline female connectors or a small project box.
