Priority and CPU Usage
Discussion in 'bit-tech Folding Team' started by cgcox1, 25 Apr 2009.
  1. cgcox1
    cgcox1 Obessed Folder! Me? Surely not!
    24 Apr 2009
    Does anybody know the answer to any of these three questions.
    How can you change the priority of VMWare Server 2.01 under Windows XP x64?
    Can you change the CPU useage of the SMP Linux client?
    Can you stop the FaHCore_xx.exe processes reverting back to low priority each time you start a new work unit?
    Cheers.
  2. uncle_fungus
    uncle_fungus P/T Folding@home developer
    27 Mar 2009
    You can alter the CPU usage of any Linux FahCores by using some software called fahlimit which can be found (along with instructions) here: http://calxalot.net/downloads/
  3. cgcox1
    24 Apr 2009
  4. cgcox1
    24 Apr 2009
    Cheers again for the link.
    Humm.... Interesting program, seems to limit the percent useage by time. Will have to give this a run and see how it affects the ppd of my gpu clients ie letting gpu clients get enough cpu useage to get there full ppd.
  5. cgcox1
    24 Apr 2009
    And as for the VMWare Server question.
    The answer seems to be to setup the VM Machines using VMWare Server, then delete VMWare Server and install VMWare Player. You then seem to be able to control the the priorities and affinities, like you used to under server version 1.08
  6. cgcox1
    24 Apr 2009
