Blue LEDs
Discussion in 'General' started by wolvattack, 2 May 2001.
  1. wolvattack
    wolvattack What's a Dremel?
    2 May 2001
    lo...can anyone tell me where can i find those blue LEDs...so far i found some at maplins but there anly for 5V power supply....how can i make them work with no problems at my computer power supply...??
    Resistor maybe??
  2. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    you need resistor!!!
    but no resistor if connecting them to your mb headers for power/hdd activity!!!
  3. wolvattack
    2 May 2001
    Thnx boss:)
  4. Koolvin
    12 Mar 2001
  5. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Why is maplins only ever have three in stock in cardiff I had to order a whole load :)
    Koolvin when you did the hdd and power ones on ure ACTS 200 did you just remove the front of the cased and solder on blue ones then heat shrink it ?
  6. Koolvin
    12 Mar 2001
    yup! I did it while the PC was ON :O
  7. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Okay I wont be trying that then :)
  8. RTT
    RTT #parp
    12 Mar 2001
    ditto :p
  9. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    Probably best with RGB now.
    fix-the-spade likes this.
  10. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    Why.....why are you replying to a 23 year old post...
  11. Mojo
    Mojo Multimodder
    18 Nov 2011
  12. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Necromancers need to practice now and again.
