hi guys i just stuck in 2 970 and they arent folding i have tried normal and advanced they just keep 13:19:23:WU00:FS00:0x17:Folding@home GPU core17 13:19:23:WU00:FS00:0x17:Version 0.0.52 13:22:11:WU01:FS01:0x17:ERROR:exception: Force RMSE error of 609.721 with threshold of 5 13:22:11:WU01:FS01:0x17:Saving result file logfile_01.txt 13:22:11:WU01:FS01:0x17:Saving result file log.txt 13:22:11:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT 13:22:12:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 13:22:12:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9406 run:941 clone:0 gen:29 core:0x17
Does it fold at all or just get that error? What temps are the cards? Have you tried deleting the slots and re-adding them? Can you post the start of your log as that will give us more information about your system and setup? Cheers. Not same card, but same error: https://foldingforum.org/viewtopic.php?f=74&t=25044
hi temps 29c on 1 and 34c on the other 17:58:34:WU00:FS01:0x17:*********************** Log Started 2014-10-05T17:58:33Z *********************** 17:58:34:WU00:FS01:0x17roject: 9406 (Run 36, Clone 2, Gen 1) 17:58:34:WU00:FS01:0x17:Unit: 0x000000020a3b1e5c533dd2c5b7af9dae 17:58:34:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000 17:58:34:WU00:FS01:0x17:Machine: 1 17:58:34:WU00:FS01:0x17:Reading tar file state.xml 17:58:35:WU00:FS01:0x17:Reading tar file system.xml 17:58:35:WU00:FS01:0x17:Reading tar file integrator.xml 17:58:35:WU00:FS01:0x17:Reading tar file core.xml 17:58:35:WU00:FS01:0x17igital signatures verified 17:58:35:WU00:FS01:0x17:Folding@home GPU core17 17:58:35:WU00:FS01:0x17:Version 0.0.55 18:00:36:WU00:FS01:0x17:ERROR:exception: Force RMSE error of 609.35 with threshold of 5 18:00:36:WU00:FS01:0x17:Saving result file logfile_01.txt 18:00:36:WU00:FS01:0x17:Saving result file log.txt 18:00:37:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT 18:00:37:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72) 18:00:37:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9406 run:36 clone:2 gen:1 core:0x17 unit:0x000000020a3b1e5c533dd2c5b7af9dae 18:00:37:WU00:FS01:Uploading 2.32KiB to 171.64.65.56 18:00:37:WU00:FS01:Connecting to 171.64.65.56:8080 18:00:37:WU01:FS01:Connecting to 171.67.108.201:80 18:00:37:WU00:FS01:Upload complete 18:00:38:WU00:FS01:Server responded WORK_ACK (400) 18:00:38:WU00:FS01:Cleaning up 18:00:38:WU01:FS01:Assigned to work server 171.64.65.56 18:00:38:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 970] from 171.64.65.56 18:00:38:WU01:FS01:Connecting to 171.64.65.56:8080 18:00:39:WU01:FS01ownloading 5.44MiB 18:00:45:WU01:FS01ownload 98.88% 18:00:45:WU01:FS01ownload complete 18:00:45:WU01:FS01:Received Unit: id:01 stateOWNLOAD error:NO_ERROR project:9406 run:767 clone:0 gen:47 core:0x17 unit:0x000000600a3b1e5c533e581ef151a0b6 18:00:45:WU01:FS01:Starting 18:00:45:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/MAIN/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8588 -checkpoint 15 -gpu 0 -gpu-vendor nvidia 18:00:45:WU01:FS01:Started FahCore on PID 5508 18:00:45:WU01:FS01:Core PID:8572 18:00:45:WU01:FS01:FahCore 0x17 started 18:00:45:WU01:FS01:0x17:*********************** Log Started 2014-10-05T18:00:45Z *********************** 18:00:45:WU01:FS01:0x17roject: 9406 (Run 767, Clone 0, Gen 47) 18:00:45:WU01:FS01:0x17:Unit: 0x000000600a3b1e5c533e581ef151a0b6 18:00:45:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000 18:00:45:WU01:FS01:0x17:Machine: 1 18:00:45:WU01:FS01:0x17:Reading tar file state.xm
Right at the start of the log file is info like this: Code: *********************** Log Started 2014-10-04T19:05:39Z *********************** 19:05:39:************************* Folding@home Client ************************* 19:05:39: Website: http://folding.stanford.edu/ 19:05:39: Copyright: (c) 2009-2014 Stanford University 19:05:39: Author: Joseph Coffland <joseph@cauldrondevelopment.com> 19:05:39: Args: 19:05:39: Config: C:/ProgramData/FAHClient/config.xml 19:05:39:******************************** Build ******************************** 19:05:39: Version: 7.4.4 19:05:39: Date: Mar 4 2014 19:05:39: Time: 20:26:54 19:05:39: SVN Rev: 4130 19:05:39: Branch: fah/trunk/client 19:05:39: Compiler: Intel(R) C++ MSVC 1500 mode 1200 19:05:39: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE 19:05:39: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl 19:05:39: Platform: win32 XP 19:05:39: Bits: 32 19:05:39: Mode: Release 19:05:39:******************************* System ******************************** 19:05:39: CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz 19:05:39: CPU ID: GenuineIntel Family 6 Model 45 Stepping 6 19:05:39: CPUs: 12 19:05:39: Memory: 15.94GiB 19:05:39: Free Memory: 14.34GiB 19:05:39: Threads: WINDOWS_THREADS 19:05:39: OS Version: 6.1 19:05:39: Has Battery: false 19:05:39: On Battery: false 19:05:39: UTC Offset: 1 19:05:39: PID: 1944 19:05:39: CWD: C:/ProgramData/FAHClient 19:05:39: OS: Windows 7 Ultimate 19:05:39: OS Arch: AMD64 19:05:39: GPUs: 2 19:05:39: GPU 0: NVIDIA:3 GK110 [GeForce GTX Titan Black] 19:05:39: GPU 1: NVIDIA:3 GK110 [GeForce GTX Titan Black] 19:05:39: CUDA: 3.5 19:05:39: CUDA Driver: 6050 19:05:39:Win32 Service: false 19:05:39:*********************************************************************** can you post that please. Not sure its gonna help, but hey.
thanks Scorpuk they have sorted it looking great https://foldingforum.org/viewtopic.php?f=18&t=26807&hilit=970&start=60 Re: New Assignment Server feedback/problem by VijayPande » Mon Oct 06, 2014 2:47 pm ok, we'll set 9406, 13000 and 13001 to be beta only for Maxwell. That should keep them away from the Maxwell GPUs and still give us beta team feedback for what's going wrong w/those WUs.
You should have bought an Iphone 6 plus.. Apparently they fold really well... If I didn't say it some one else would have done
