News Bethesda releases Fallout 4 PC system requirements
Discussion in 'Article Discussion' started by Gareth Halfacree, 9 Oct 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. Spigsy
    Spigsy What's a Dremel?
    28 Sep 2009
    Seems to be a considerable disparity between the AMD and Nvidia minimum and recommended GPU spec. The 7870 is typically more than twice as fast as the 550ti; the GTX780 is more equivalent to a R9 290- which still beats it by a decent margin in most games.
    Either way, I expect the requirements to be excessive, especially a few months in when the game will likely receive some performance optimizations.
    I hope the increase in required GPU memory means an improvement in Bethesda's typically horrible textures.
    Anyway, now the bitch inside me is sated- I'm actually really looking forward to this!
    Almightyrastus On the jazz.
    21 Mar 2002
    Right then, upgrade time /*rubs hands together*/
  4. IT Troll
    IT Troll What's a Dremel?
    27 Aug 2009
    There are people with 8GB RAM and a 32-bit install of Windows? :sigh:
  5. Gareth Halfacree
    4 Dec 2007
    There are certainly people with 4GB of RAM and a 64-bit install of Windows, hence "and". (Incidentally, there's no reason a 32-bit Windows install couldn't access >4GB of RAM - Google "physical address extension.")
  6. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Looks like it's upgrade time! Not sure if that merits :waah: or :rock:
  7. Taniniver
    Taniniver Minimodder
    24 Aug 2010
    Good! It's long overdue for PC games to require a 64 bit OS and more than 4 Gb of RAM.
    That 4 Gb limit has been holding things back for years - games companies had to cater to lowest common denominator and make their games able to run on low end systems, restricting development to fit within this limit. Even the current generation of consoles have more RAM, and the PC is supposed to be ahead of the game!
    I applaud Bethesda's decision.
  8. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    And yet it will still be optimised for consoles and *******ised for the PC.
  9. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Not wanting to bash Microsoft but isn't the 4GB limit more of a design choice that a technical one, as in 32bit Windows could technically address more than 4GB but Microsoft chose to draw the line at 4GB for marketing reasons and the problems caused in Windows when using PAE.
    Games companies had to cater to lowest common denominator yes, but that wasn't caused by low end systems (users) it was caused (IMO) by gaming on Windows having stagnated for the last 13 years.
  10. Panos
    Panos Minimodder
    18 Oct 2006
    At last. Lets kill the damn Win 32 for heaven sake. There hasn't been a 32bit CPU on sale for 12+ years.
  11. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    I was working on a customers machine, who had 32 bit windows and 8GB ram, I did suggest to lads I was working with that they should upgrade to 64bit
