Scratch Build – In Progress BenChair
Discussion in 'Project Logs' started by Ironknocker, 10 May 2014.
  1. Ironknocker
    Ironknocker Minimodder
    4 May 2014
    Germany
    Hi i'm the new guy for Germany.
    At first sorry for my bad english.
    Last year in September, I started planing a new project.
    It set a workstation to the CAD drawing, games and for benching
    So i draw a 3d model of the Chair.
    Then began the search for sponsors
    My thanks goes to:
    Aquatuning
    Cooler Master
    Eizo
    Sandler
    Eizo sent me 3 monitors
    Cooler Master cases, power supplies, fan and Input Devices
    and Aquatuning water cooling, electric, logic controllers and fans.
    And Sandtler the seat.
    Then the rebuilding began.
    First, the monitor mount was my turn.
    Next i build the frame.
    1. the base
    Then the backframe
    Then the roll bar
    The reserve tank I built from a stainless steel tube.
    Next, a test build of the water cooling
    The armrests were of course also motorized.
    Then the trim was on the series
    The hardware then took his place
    Now comes the current state of the project.
    Last weekend I made ​​the armrests and the foldable desk.
    Here's are a couple of clips of the various functions.
    c
    The Worklog has more than 600 pictures.
    All pictures until today there at.
    we-mod-it.com
    That's it for now. Next update next week
  2. morgansk
    morgansk I've got wood
    12 Jan 2013
    Manchester, UK
    This is insane! I'm wondering how you will get this thing into your house, it's massive and looks extremely heavy too. Nice work, loving all the moving parts too.
  3. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Netherlands
    I always love a good racing cockpit type project. Looks great. Kinda sad to see the holes covered as the structure looked very cool. But you are putting the hardware in it which makes up for that. Do keep us updated.
  4. ToddK
    ToddK What's a Dremel?
    3 May 2014
    Edmonton
    Awesome, want!
  5. trintragular
    trintragular What's a Dremel?
    29 Oct 2012
    Very impressive and certainly a creative approach.
    As pointed out by morgansk, moving it about might be a bit inconvenient but I bet you have a plan for that.
    Do you have any long-term concerns over the weight of the monitors?
  6. DeMoB
    DeMoB All of my Dremel wheels are broke!
    10 Jul 2008
    This is an amazing project, but do you not think the adjustment motors are a little slow?
    If you've got to sit there and wait in excess of a minute before you can do anything else, I'd be a bit frustrated at its slowness. Especially if you need to move the screens up to get out of the chair and you needed to quickly get out and back in to grab something.
  7. chilliewillie
    chilliewillie What's a Dremel?
    14 Apr 2014
    i want to be youre best friend
  8. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    Berlin Germany
    hey bro eisenklopfer, welcome to the uk forum.
    nur english here my friend... dann gehts dir so wie es mir geht immer.
    danach die knoten aus der zunge raus nehmen.
    wow ein riesen worklog alles auf einmal.
    its looking great though. bye ali
  9. Ironknocker
    4 May 2014
    Germany
    @morgans: The chair can be disassembled into 6 parts. Seat adjustment, base, rear, roll bar and monitor mount.
    He will weigh about 200-300KG.
    @trintragular: The monitor mount with monitors weigh 25 KG. Should not be a problem
    @DeMoB: yes the engines are not the fastest but the have power. But I will later spindles with a different slope then take going the faster. For the lift motor I have unfortunately not found a better solution.
    Has anyone got a better idea?
    @ ali: werd mich bemühen hoffe du vermittelst wenn ich was nicht richtig oder falsch verstanden hab :D
  10. JD Design
    JD Design What's a Dremel?
    13 Feb 2014
    Great project, very nice welding work, I very much like the idea.
  11. Randhart
    Randhart What's a Dremel?
    26 Apr 2014
    This is an amazing project your welding work is great and I really love the idea just wish my flat had space for one ;)
  12. Ironknocker
    4 May 2014
    Germany
    Update.
    First, I have cut the right armrest adjustment for the point where the table rests
    Next, I drilled threaded into the holders of armrest adjustment.
    Since a screw comes in with which I can make all in balance.
    Finally, there was a few sheets for the limit switch adjustment
    Then I done the seat frame finished with armrests. In addition I have welded all welds, ground and made ​​splashes away.
    This Flex are used with serrated washer and milling cutter with tungsten cutter.
    And that is it came out.
    On the seat adjustment and the Mainboardtray I also weld sheets for the limit switches.
    Recently, I then made ​​the motor mount ready which lift the
    complete roll bar with the help of gas dampers.
    The first parts are available only in my garage. Hope by the end of the month are all there:-D
  13. Ironknocker
    4 May 2014
    Germany
    BenChair Update 18.05.14
    Update
    So at the weekend I work on the lift engine.
    With Felx shaft coupling it don't work, with the elastic it works much better.
    The little engine creates have the power to lift the bar.
    I have not made it out of the pivot point.
    [video]http://www.youtube.com/watch?v=38jMb_ww0v4&feature=youtu.be[/video]
    Der Motor wird dann Später von 2 Dämpfern unterstützt dann geht das viel leichter.
    Then we went to the grind and weld.
    Here's a Before After comparing what I've done with all welds.
    In the lower part, I have welded dying and screwed adjustment screws.
    Now he has already found his future place.
  14. Ironknocker
    4 May 2014
    Germany
    BenChair [Update 25.05.14]
    Today I have work on the monitoring and control unit
    First I canted angle and mark the cutout.
    Next, I attached the hinges because the displays can be folded down later.
    Then I divided the sheet again so it is not to big and does not protrude into the monitors.
    When done what I have made ​​the handles for the detent adjustment of the displays.
    As a Break point I welded a brace with a guide at the temple.
    So what it looks like now.
  15. darknessblade
    darknessblade What's a Dremel?
    23 May 2014
  16. Umbra
    Umbra What's a Dremel?
    18 Nov 2013
    Windscreen wiper motors are quite powerful with good torque, 12 volt
    motorcycle starter motors are powerful, 12 volt
    Great build, just right for playing Mario Kart :D
  17. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    The Netherlands
    wow that is some serious metalwork.. Wish I had the skills to make something like this. Very very cool :)
  18. Sn00k3r
    Sn00k3r What's a Dremel?
    7 Apr 2011
    Zurich, Switzerland
    Wow, wie geil ist das denn..? Daumen hoch Junge, ein echtes Monster..! :thumb: :D
    Niiiiice, what a monster..! :thumb:
  19. Ironknocker
    4 May 2014
    Germany
    Last weekend i was on the Modding Masters at the Maker World in Friedrichshafen in Germany.
    The Chiar is 80% completed
    200m cabel.
    7L Watercooling
    178Kg wight
    Here we go to the paint and sanding
    And a clip form the Modding Masters
  20. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    You need a foot rest!
