Case Mod - In Progress H.A.F. REBORN - Completed!
Discussion in 'Project Logs' started by neSSa, 12 Oct 2015.
  1. neSSa
    neSSa Multimodder
    11 Aug 2014
    Project is finished, you can see more pictures on 6th page
    For a long time I was totally focused on benchtable and so followed projects based on them, but now I'm going back to my old love "PC Cases". Although I can not think of any possible on the market that could satisfy me the way he came out of the factory , there's one that I'm particularly emotionally attached to, no matter what its shortcomings. From there came the idea with the intention to try to bring the same to the level of perfection, technologically and aesthetically and functionally.
    Case that has been resisting the technical novelties but so many times has been used on the modding scene, which I've already been working on by bringing together two of the same in "Cubex" PC mode (http://www.sspcmodding.com/cubex/), now comes to order as an undying idea to incorporate, on and in him, so much more! It is His Majesty the HAF 932 and HAF hence the name Reborn as the rise of the phoenix :)
  2. neSSa
    neSSa Multimodder
    11 Aug 2014
    so let's go, CNC laser cut for the same parts is the finished :)
  3. neSSa
    neSSa Multimodder
    11 Aug 2014
    Here's a little more photos of finished elements...
  4. neSSa
    neSSa Multimodder
    11 Aug 2014
    These circular spacers were cut from 10mm acrilyc and serve as spacers for switches (start , reset and lighting ) and why I had to make them you'll see a few days later when I install all :)
  5. neSSa
    neSSa Multimodder
    11 Aug 2014
    6 Cooler Master SickleFlow 120mm line that will be used on radiators (sleeved MDPC black)
  6. neSSa
    neSSa Multimodder
    11 Aug 2014
    Power that is owned for a year or so, dangerous little one :)
  7. neSSa
    neSSa Multimodder
    11 Aug 2014
    something is hidden between a lot of old stuff in the attic :)
  8. neSSa
    neSSa Multimodder
    11 Aug 2014
    measuring, cutting, filing, sanding ...
  9. neSSa
    neSSa Multimodder
    11 Aug 2014
    To strengthen the structure, I put 1x1cm stainless steel skirting.
  10. neSSa
    neSSa Multimodder
    11 Aug 2014
    6-32 screws for PSU have arrived :)
  11. neSSa
    neSSa Multimodder
    11 Aug 2014
    back side and mb try fits perfectly :)
  12. neSSa
    neSSa Multimodder
    11 Aug 2014
    HDD rack, now slightly redesigned, adapted for 3xHDD 3.5" and 1xHDD (or SSD) 2.5"
  13. neSSa
    neSSa Multimodder
    11 Aug 2014
    Spacers :)
  14. neSSa
    neSSa Multimodder
    11 Aug 2014
    motherboard fits perfectly into place, I have to buy longer Extenders :)
  15. neSSa
    neSSa Multimodder
    11 Aug 2014
    switches...
  16. neSSa
    neSSa Multimodder
    11 Aug 2014
    Here comes the support of Cooler Master's office. Again my gratitude for trust!
    There are power supply CM V1000 and JetFlo fans, soon in real photos :)
  17. neSSa
    neSSa Multimodder
    11 Aug 2014
    I present to you Cooler Master V1000 psu :)
  18. neSSa
    neSSa Multimodder
    11 Aug 2014
    morning surprise, dual PSU adapter, 30cm long arived :D
  19. neSSa
    neSSa Multimodder
    11 Aug 2014
    1850W together , he he he, thanks Cooler Master :D
  20. neSSa
    neSSa Multimodder
    11 Aug 2014
    I present to you 6 pack CM JetFlo 120 RED
