Hello all, I was wondering if anyone could suggest a mid-tower case able to house a large two 120mm fan radiator internally? As far as I can tell, a few of the budget cases can mount thin radiators in the roof but I've got a 60mm thick TFC beast which I've had to bolt onto the side of my current case. If this is unrealistic then does anyone know of a small (ITX sized) case which I could mount the radiator onto externally without having to drill any new holes? Thanks
If you have a bigger budget, perhaps the Lian Li v600f. It has dual 120 mount in the front, and plenty of room if you pull out the 3.5" hdd rack while being on the smaller side of matx mid tower. example found...
I have a dual 5.5" bay reservoir I need to accommodate, so mounting it at the top would be best I reckon. That Fractal Arc Midi looks like it'll fit the bill though Thanks
The NZXT phantom range in my opinion are really good. The mid-tower (Phantom 410) has 8 slots for fans and a huge space on the top for a 240mm radiator. It has plenty of space and is really practical
