Case Mod - In Progress Hi-Tech armoured case by DJB Modding
Discussion in 'Project Logs' started by Diegojavbau, 16 Mar 2012.
  1. Diegojavbau
    Diegojavbau What's a Dremel?
    13 Jul 2011
    Hi , I'm here with my new project Hi-Tek armoured case
    Is a Thematic mod , inspired in games like Crysis 2 and MGS 4 , the main
    idea is to develop a computer armoured with the technology of
    nannosuite 2 and Snake armoursuite
    Let's start with the side panel design (basic)
    I made this pieces in MDF (1/2 inch) to get the desire shape
    First the cuts
    Every piece must be worked manually to get it into shape
    Example
    More pieces
    Panoramic view of the working area [​IMG]and tools used
    Half-side panel done , three picture of different angles
    Pieces of the two side panel (it will be symmetrical) confronted to compare
    A simple video of the process
  2. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    I like it so far - subbed. :)
  3. Diegojavbau
    13 Jul 2011
    More pieces for the side panels , almost done
    Left
    Rigth
    More pieces made in MDF , this time in 5mm of thickness
    Pieces glued in place
    I worked on them to make the edges rounded
    All the pieces together , this is for the fans of the top of the case
    Same for the side panel
    Complete side panel preview , with this new pieces , I can have 3 different highs , to make it look less flat than before
  4. fuchskqpf
    fuchskqpf What's a Dremel?
    17 Mar 2012
    like it so far -
  5. jhanlon303
    7 Sep 2006
    This is noce. I like it.
    john
  6. bulldogjeff
    2 Mar 2010
    This is off to an interesting start. I'll have to keep watching.
  7. Elladan
    Elladan Minimodder
    17 Mar 2012
    Nice job, really like it :thumb:
  8. Dragonphreak
    Dragonphreak Minimodder
    26 Oct 2005
    I really like this design, reminds me of some alien armor.
  9. Diegojavbau
    13 Jul 2011
    Thx people
    That's the idea , if you see an armor , I'm doing things right , thx for the comment
  10. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Nice! I'm working on actual armor, we'll have fun watching your come together!
  11. Diegojavbau
    13 Jul 2011
    GREAT !!!
    That seems weird !!!! LOL
  12. KayinBlack
    2 Jul 2004
    Typo. I hate my keyboard. It's only 25 years old.
    I'm having fun watching you put this together. That should work better than what I posted the last time.
  13. Diegojavbau
    13 Jul 2011
    I hope that keep it that wat , but usually there's "surprises" to correct when is time to assemble everything
  14. Diegojavbau
    13 Jul 2011
    More pieces using the same materials and techniques , this time for the top of the case
    Drawing
    Cut
    Edges cut in angle
    Finish using rotary tool and sand paper by hand
    Some pictures in different points of view of a case-top preview
  15. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Wood man :)! You are doing great!
  16. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Feels like inspiration came from H. R. Giger, i like!
  17. dirky90
    dirky90 Minimodder
    19 Mar 2012
    you cant beat working with 'wood'!!!
  18. Foregasm
    Foregasm What's a Dremel?
    3 Apr 2012
    great skills bro
    subbed
  19. Sarakon
    Sarakon The German
    11 Feb 2011
    That looks super epic :D
  20. Diegojavbau
    13 Jul 2011
    Thanks !!!!! :D:D
