Hello people, I need your help deciding on a headphone. Skullcandy Hesh OR Koss PortaPro There is hardly any price difference. Skullcandy looks good with good sound. Koss is supposed to be the best for this price range but looks crap and entangles with hair. Any comment/suggestion is appreciated. Cheers.
Personally I've never heard anything good about the skullcandy apart from the looks. Go for the retro goodness!
PortaPro definitely, if you care about sound quality at all. If you don't like how they look, you can try the Koss KSC75, which uses the same driver but is clip-on instead.
What's your budget? If I I were you I'd go with either Sennheiser or if you have more money to spend of a really really good set of earphones I'd go Shure.
My budget is £20. I do not want anything fancy. I just want something that is durable with good sound. If there are headphones with comparable price, I would obviously like to have the one with better sound quality and that is the reason for my query.
