Other Android kit Kat 4.4.2
Discussion in 'Software' started by Kovoet, 20 Mar 2014.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Just heads up for those who haven't got it yet. My galaxy 4 updated today with kitkat.
  2. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Mine did last week. I factory reset after the install too, just to be safe.
    Sent from my GT-I9505 using Tapatalk
  3. Dazza007
    Dazza007 What's a Dremel?
    9 May 2009
    Can I ask why youve posted a thread about this? The reason I ask is mine updated 3 days ago and its running a lot worse ever since. Battery drains really quickly. Takes twice as long to charge. Phone runs very hot when the only thing running is facebook via browser. Im beginning to HATE android.
  4. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    ...because iOS updates are always perfect?
  5. Dazza007
    9 May 2009
    iOS
    I wouldnt know, never had one. My last phone was a Nokia N8 running Symbian. It had this neat feature were if you close an application it actually closed. This single feature meant my battery would last over 1 day. Honest o god.
  6. Kovoet
    26 Aug 2009
    Mine has been ok. All I did was update all my apps and never had a problem since then.
  7. Dazza007
    9 May 2009
    android
    My main complaint is I cant find out whats hogging the cpu. Ive updated everything I use. Got a small list of apps I dont use so never update.
  8. landspeeder95
    landspeeder95 What's a Dremel?
    11 May 2010
    I had the SAME problem with the HTC One (m7) - now solved.
    Using 'Carat' from the play store I was able to see that my beloved app Photobucket was now no longer allowing Android to sleep. I also removed 7 other apps that were sucking the life from my phone.
    As an aside - if your phone is unlocked and well supported on Cyanogenmod I HIGHLY recommend moving to it. 1- you can use custom key mappers and 2 - no bloatware forced upon you and your battery.
  9. Teelzebub
    27 Nov 2009
    Had the update couple of weeks now no problems at all. and I had another one a few days later
    Battery last three days on my Sony Xperia Z1
  10. Dazza007
    9 May 2009
    Im not sure what you mean, im a novice to android. Ill install carat now and take a look. Cheers.
  11. dancingbear84
    16 Oct 2010
    Back up everything then factory reset.
    Don't blame me for lost data.
    I've always done this from the really old 1.5 upgrades caused me issues back in the day. Never had any issues since doing resets after upgrades.
    Never heard of carat can't comment.
    Also if you go to settings, more, battery you can see what is hogging memory and resources that way.
  12. Dazza007
    9 May 2009
    I don't know how to back everything up and reset, kies?
  13. GeorgeK
    18 Sep 2010
    I had the same problem with my Galaxy S4. I had a good read around and what worked for me was going into application setting and uninstalling the updates for Google Play services. Now my phone is perfectly fine again - battery actually lasts longer than before I think.
  14. Dazza007
    9 May 2009
    s4 running hot
    Right, ive managed to track it down to the default web browser on the s4 on 3, it looks like an earth. Run this and I can smell the heat coming off my phone. Run chrome, which heats the phone up but not as bad.
    I tried Carat which flagged up iPlayer. So far thats all its found.
