Build Advice pc wont boot with a certon gfx card in it
Discussion in 'Tech Support' started by Elspuddy, 5 Sep 2010.
  1. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    i got an 500w psu (was a 400w) abit ib9 mainbord a evga 8800gt and a ati 3400 4 gig ram (2x1gig , 1x2gig@667) , if i plug in the 8800gt it wont post (no bleeps fans always on) but if i put the ati card in it runs fine (powers up then down then up again then bleeps as normal), any idears ?
  2. Chanc3
    Chanc3 What's a Dremel?
    22 Jun 2010
    Reset BIOS?
  3. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    resting the bios now gives me 4 bleeps when it try's to boot
  4. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    might be a bad 8800gt.. seen this before too- if you can rma it
    that's assuming (yeah I know) your ps is single rail and you plugged in correctly.. if it's not single rail- make sure your not overloading any of the 12 volt rails with 4 to 6 pin splitters
