Scratch Build – In Progress Project Facit, almost finished! 6th July 2013
Discussion in 'Project Logs' started by vils, 6 Aug 2009.
  1. vils
    vils What's a Dremel?
    4 Jun 2006
    I had an old electrical typewriter from the Swedish manufacturer Facit at home for the kids to play with.
    It was a huge 40 pound heavy mechanical wonder, its die cast aluminium shell crammed with springs, levers and other components. It looked like this:
    A couple of years ago I made a mod called "All work and no play" and I missed the wonderful feeling of creation so some while ago I snatched the kids typewriter and began planning.
    First of all I disemboweld the machine, 18 pounds of complicated metal parts ended up in a "good to have" box.
    I decided to make room for a regular PSU a MATX mobo, one or two HDD's and a slim-lin slot in DVD.
    Things have moved slow since then, but now the basics are done.
    Here are the lower part of the shell, with the DVD slot visible:
    Lower system tray with PSU holder, grommet mounts for HDD, hacked fan and thick metal slab for DVD mount:
    Mobo tray in place:
    Interior mounted in shell with anti vibration grommets:
    The part that so far have caused the most headache:
    Front mounted:
    Keyboard and roof in place:
    Last major part mounted:
    There are as you can see many things to work with in this project but for the first time I can really see this coming to an end.
    The rectangular hole to the left of the KB I will have a "glowing letter" indicator for HDD activity, caps lock, num lock and so on.
    I will propably have the case powder coated to replicate it's original finish.
    One of the reasons for all the time this have taken is that it's really is a zero budget project.
    I have used scrap material and leftovers. I have bought some metal filled epoxy, some screws and the anti-vibration grommets.
    The two most expensive parts so far is a rubber silenced HFX DVD drive I picked up on a sale and the refurbished SMK-85 keyboard.
    It will propably continue to be zero-budget in the near future so every steps that require cash will have to wait.
    Last note: sorry for the whitebalance in the pics, I will try correct this later on.
    Thank you for looking!
  2. Monkey Puzzle
    Monkey Puzzle Minimodder
    18 Feb 2009
    Looks very nice so far.:thumb: Would look nice and authentic imo if you could colour a few keys red as for the original.
  3. vils
    4 Jun 2006
    Thanks! I have saved all old keycaps and I'm working on a way to use them on the ALPS switches... very complicated with spacing issues, but couloring some red could be a way to go.
  4. jhanlon303
    7 Sep 2006
    I like this a lot! :thumb:
    I watch.
    john
  5. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    +1 :D Red keys would deffo look good. Looks good keep it coming man!
  6. vils
    4 Jun 2006
    I'll just add some more info:
    The mobo-tray and bottom tray are made of 3mm thick aluminium, the distance between them are 30mm.
    Between the mobo-tray and "ceiling" the clearance is just over 120mm.
    The "lid" over the interior is made of two sheets of 2mm aluminium epoxied together, strong enough to let a TFT to stand on.
    The keyboard is as said a SMK-85 with Strongman/ALPS switches wich have a distinct clicky sound. I think this goes well with the machines origin.
    I will definitly try to adapt the keycaps so that they blend in even more.
    Thanks for the feedback and don't hesitate to ask questions, I'll answer them as swift as I can.
  7. stonedsurd
    11 Mar 2009
    Typwriter Cheesecake! Love 'em.
    subbed :thumb:
  8. Cheapskate
    13 May 2007
    That is slick.
    Where's the paper go?:naughty:
  9. Krog_Mod
    Krog_Mod Minimodder
    23 Sep 2003
    That would be really interesting if he could somehow work a printer into this as well.
  10. vils
    4 Jun 2006
    I have test installed an old (unusally small) mATX mobo and a dead PSU to clarify the layout:
    The installed mobo is only 190mm deep, but there is room for the standard 244mm as you can see.
    I suppose it would be possible to squeeze in a small printer as well, especially if I had choosen a ITX solution with a PicoPSU. But this will be my main rig so I prefer power instead of the printer, wich would be more of a gimmic.
    BTW, my last mod had some typewriter theme too:
    This is unfortunatly a unlit comp pic, I had the log hosted a the now late systemcooling.com and most of the pics are lost.
  11. Cheapskate
    13 May 2007
    :lol: Nice window idea.
  12. Monkey Puzzle
    18 Feb 2009
    Heh, is that a dead Hiper PSU?
  13. vils
    4 Jun 2006
    That's right, dead 580w Hiper.
  14. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Nice work as usual, Vils. Nice to see you in action again.
  15. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    You need to mod a portable printer into that asap!
  16. vils
    4 Jun 2006
    I have worked hard the last two weeks in my not too abundent spare time with epoxi and sanding. Pics will arrive when I'm finished with this stage.
    My first idea was to powder coat the case with a colour that is close to the original finish, after speaking to some powdercoaters I think I'll have to abandon this idea.
    The epoxi I have used will propably not withstand the 220 d C baking temprature for powder coat.
    I have thinked about using a dark metallic gray hammer finish paint from rust-oleum. Unfortunatly this paint seems to be unavailable in the EU and they, so far, don't answer my e-mails.
    Another option is to take the case to a car painter and give it a mirror finish dark grey.
    But I'm really uncertain about wich finish to strive for, ideas are very welcome.
  17. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    hey, how'd you get the writing on the window? is all that etched?!
  18. vils
    4 Jun 2006
    It's laser engraved. Can't remember wich company that made it.
  19. Combinho
    Combinho Ten kinds of awesome
    5 Aug 2008
    That typewriter is looking very nice. I look forward to seeing it completed.
  20. vils
    4 Jun 2006
    My connection is for the moment horribly bad, I'll just post some pics and comment later.
