CPU What do I need to claim warranty of cpu?
Discussion in 'Hardware' started by phinix, 7 Mar 2017.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    If I buy CPU on ebay, used, no box etc but something happens to it - can I claim warranty directly with Intel?
    Using this FPO number?
    Would I need initial proof of purchase?
  2. Bazz
    Bazz Multimodder
    7 Oct 2009
    Intel will only honour the original owner, if its a retail product 3 years, OEM is with the seller.
  3. phinix
    28 Apr 2006
    Damit!
    OK, thanks for confirming this, I was worried this is the case:duh:
    Back to shopping then...
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Intel will honour the warranty of 'Retail' chips with the details from the chip only, you do not need the original receipt or to be the original owner. This is not the case with chips sold as 'OEM'.
  5. phinix
    28 Apr 2006
    Right, I typed this FPO number of the chip on Intel website and it said it is 3 year retail.
    Does it mean if I buy it and sth happens they won't ask where I got it from?
  6. TeleKomune1
    TeleKomune1 What's a Dremel?
    6 Feb 2017
    I mean they'll ask where you got it from, but you know ;)
  7. TheMadDutchDude
    23 Aug 2013
    They have never asked me where I got my CPUs from. It's in warranty, so it shouldn't be questioned. Try to talk to them through the live chat and see where you end up.
  8. Mister_Tad
    27 Dec 2002
    Has anyone ever in history needed to claim against a CPU warranty, other than DOA?
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
    Once, back in Slot 1 days.
  10. edzieba
    14 Jan 2009
    I've claimed a 2500k at one point (duff memory channel).
  11. mrbungle
    20 Sep 2004
    Just so you know the FPO number they go off for the theoretical warranty also shows up some OEM chips as being in warranty... to the extent they will send you a returns courier FOC.
    Even if they don't ask for the heatsink serial to confirm the item is retail they then check the ATPO serial which you need a magnifying glass/microscope to read on some later CPU's. This can then reveal your "retail" chip by FPO number as a OEM.
    Ask me how I know this :miffed:
  12. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Yep it happens very often in benching circles. There was a guy on OCN (iirc) who bought a 5960X and had it replaced two or three times under warranty because he kept killing it during bench runs. Beats me how he managed to explain that one to Intel, but my guess is that it died within safe voltage spec.
  13. edzieba
    14 Jan 2009
    Intel offer an extra warranty for that.
  14. Mister_Tad
    27 Dec 2002
    Interesting.
    I always had a CPU pegged as something where if it works out of the box, it's almost certainly going to work until the end of time, barring blatant abuse.
  15. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    I had to send a 6700 back to get a replacement - original would boot into BIOS, all temps, cores and voltages were as to be expected, but as soon as I tried to install Windows - infinite boot loop.
    But aside from that, CPU's have always been plug'n'play for me too.
  16. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Yeah I remember when that was introduced, but the guy I'm talking about had his chip replaced under the standard warranty, much to everyone's bewilderment.
  17. wolfticket
    19 Apr 2008
    That's probably largely true baring the odd exception. It certainly the last place I expect or look for a failure. I think it's basically because the manufacturing tolerances are necessarily ridiculously tight and it is a discrete first party component.
  18. TheMadDutchDude
    23 Aug 2013
    He had it replaced under standard warranty because there's no way for them to know it was abused. Your warranty being voided by an overclock is a complete lie. ;)
    If you tell them it's unstable and needing more voltage at stock to work or even that you've swapped it out with another processor, you've pretty much got yourself an instant RMA. That is of course if it is still in warranty...
  19. wolfticket
    19 Apr 2008
    I suppose the reason they are fairly generous with warranties is that the actual cost of manufacture doesn't make for a particularly large portion of the value of the processor, so as long as you send back the dodgy as proof it doesn't actually cost them too much to replace like for like.
    Combine that with the rarity of failures and they're probably better off keeping customers happy and on side in future.
  20. phinix
    28 Apr 2006
    Hmmm.. there is one 7500 on ebay and guys says it's box version however selling without one.
    When used its FPO on Intel's side it showed that it should be boxed...
